Hi
I can import from iTunes .m4a by drag & drop, but I can't do the same with m4p format, in fact I can't get .m4p into audacity by any means. When I try importing/drag & drop I just get a blank timeline. Any help will be appreciated.
importing audio ?
auctioneer
Re: importing audio ?
Audacity does not support m4p files. Use iTunes to export as uncompressed WAV files.
http://docs.info.apple.com/article.html?artnum=93123
auctioneer
Mission Accomplished...thanks!
