New MAC user - old PC user
billw58
Re: New MAC user - old PC user
Post by billw58 » Fri Jul 23, 2010 6:35 pm
kozikowski wrote: "Connect your MacBook Pro to a line level microphone or digital audio equipment."
Well, that straightens it all out. I know we all have multiple Line Level Microphones around the house.
:D
Yeah, clear as mud. Why can't they just call it a line level input? I think it goes back to the days of the "Apple Microphone" that had a built-in pre-amp. That was a "line level microphone". Perhaps the one and only ...
-- Bill
bgravato
Post by bgravato » Fri Jul 23, 2010 7:28 pm
Looking at that pic I remember I've already seen one of those 3 rings jack connector in some mobile accessories... I wasn't aware that newer MBPs had that kind of socket... In that case I take back what I said previously...
Koz, another way they could detect wether it's a mic or line-in connected to the input socket is by the kind of jack connected: if it's mono assume it's a mic, if it's stereo, then it's line-in... Although if I had to bet I would put my money on the impedance detection...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by kozikowski » Fri Jul 23, 2010 8:43 pm
<<<if it's mono assume it's a mic>>>
Lovely idea, but they use the same connector.
http://www.kozco.com/tech/audioconnecto ... ctors.html
bgravato
Post by bgravato » Sat Jul 24, 2010 1:04 am
Most mics I've seen with a jack connector have a mono jack. I haven't seen any with a stereo jack... (at least on the cheap/crappy ones :P)
Post by steve » Sat Jul 24, 2010 1:34 am
"Computer microphones" almost always have a "stereo" jack. This is not because they are stereo, but because they are "electret" microphones and require a low voltage (5 v) power supply to operate. The additional connection on the mini-jack plug is used to supply a low voltage to the microphone capsule.
Post by kozikowski » Sun Jul 25, 2010 8:58 pm
The problem with computer microphones is you have to plug them into a computer or a device that simulates a computer and supplies battery. They won't work plugged in anywhere else.
The Radio Shack 3013 microphone...
http://www.radioshack.com/product/index ... Id=2102927
...has a little watch battery internal and doesn't need the computer battery. It does have a mono connector. Tip and Shield. No ring. It will plug in anywhere, computer or not.
If you have a modest dynamic (moving coil) microphone, those doesn't take batteries at all and one of those may have a mono connector.
pdxrunner
Post by pdxrunner » Fri Jul 30, 2010 5:19 am
Update.
I got my "Headset Buddy" adapter on Tuesday, so I now have the headset (and it's mic) plugged into the MBP headphone jack for Skype, and the E-MU on USB for recording and music listening. So far there's been no problems switching back and forth between Skype, Audacity and iTunes. I stay logged into Skype (it's now my "office" phone) all the time, but obviously don't use the audio while I'm recording from the E-MU. So far I've had less trouble getting everything working to my satisfaction on the Mac than I had on the PC in the past.
PDX
Post by kozikowski » Fri Jul 30, 2010 5:56 am
<<<So far there's been no problems switching back and forth between Skype, Audacity and iTunes. >>>
We're taking bets on when your Mac turns into a simmering pot of grog. Buanzo is holding the bets in an unlisted account in Argentina. I placed no more than 30 days. Anybody else? Anyone?
Post by steve » Fri Jul 30, 2010 11:36 am
kozikowski wrote:I placed no more than 30 days. Anybody else? Anyone?
I'll put my money on pdxrunner - If he was still on Windows 7 I'd be betting the other way, but a Mac is basically an expensive Linux box isn't it ;)
I have a similar set-up on my Linux laptop (internal sound card for Skype, USB sound card for listening/recording music) and switch between the two depending on what I'm doing - it works well for me.
pdxrunner
Post by pdxrunner » Sun Aug 01, 2010 3:26 am
OK Koz, you had me snorting tea all over the pretty Mac keyboard. Actually, I think it's like Steve said, I keep my Skype audio on completely different i/O devices than I use for Audacity or iTunes, or any other general audio listening. The real test will come in a couple weeks when I'm traveling away from my home office (and the E-MU) and I have to use the headphone jack for everything. Koz, you may still win that bet!
PDX
