Audacity Not Recognizing FFMepg Lib.
SteveBC
Post by SteveBC » Sat Jul 17, 2010 5:58 pm
I tried installing the FFMepg Libraries to the automatic location as per standard installation which is usr/lib/audacity/ffmpeg libraries. The install wizard said the installation was successful. When I opened Audacity, It said the FFMpeg file "libavformat.52.dylib I'm installing the the FFMpeg for Snow Leopard 10.06.
I went th discussion board where it suggested that the tthe installation directory to the application/Audacity Folder. I could actually see the file below in the folder. However , when I pointed for the Browse in Audacity's preferences, It still said the below lib file /Applications/Audacity/audacity/libavformat.52.dylib
YI am still new to Mac especially when it ti making changes in the system Library. For this reason I elected out of building the FFMpeg File Libary as described on the Alternative Installation page. Would some please help me out with this or some suggestions.
Regards,
Steve C.
Re: Audacity Not Recognizing FFMepg Lib.
Post by Gale Andrews » Sat Jul 17, 2010 6:26 pm
As it says in the Manual, the FFmpeg libraries will be installed in /usr/local/lib/audacity. That is where you need to install to and browse to.
