Track Labels
iew
Track Labels
Post by iew » Sun Dec 20, 2009 10:44 pm
I recorded an album and went back to add song titles. When I converted to aac and imported into I Tunes all I got was one long song not broken into individual songs. What did I do wrong, no problem with earlier Audacity?
Mac OS 10.6.2
Audacity 1.3.10
billw58
Re: Track Labels
Post by billw58 » Mon Dec 21, 2009 12:16 am
1.3.10 has a problem with export multiple - it round the songs up to the nearest 5 seconds. Try the latest nightly build of 1.3.11 to get around that.
http://www.audacity.homerow.net/index.php?dir=mac%2F
Scroll to the bottom of the list, then click on the last entry to get to the link for the .dmg.
As for one long track and not dividing into songs, that is strange. Your message implies that you have done this successfully before?
Have you looked at this http://manual.audacityteam.org/index.ph ... o_CD#split
Audacity is not the best program for making AAC files. I usually export to AIF (complete with metadata), import them into iTunes, let iTunes convert to AAC, then trash the imported AIFs from iTunes. I have iTunes set to copy files into the library, so your original AIFs are not touched. Sounds complicated, but it's faster.
-- Bill
iew
Re: Track Labels
Post by iew » Mon Dec 21, 2009 12:24 am
I normally use AIF and let Itunes do it also.
waxcylinder
Re: Track Labels
Post by waxcylinder » Mon Dec 21, 2009 11:04 am
billw58 wrote: I usually export to AIF (complete with metadata), import them into iTunes, let iTunes convert to AAC, then trash the imported AIFs from iTunes. I have iTunes set to copy files into the library, so your original AIFs are not touched. Sounds complicated, but it's faster.
-- Bill
Bill,
I have been exporting at 16-bit WAV and then letting iTunes convert to AAC (similarly trashing the imported WAV files).
Would I be better using AIF export from Audacity, rather than WAVs, to feed the AAC conversion?
WC.
billw58
Re: Track Labels
Post by billw58 » Mon Dec 21, 2009 4:46 pm
WC:
I use AIF mostly from habit being a Mac guy. But I understand that AIF has better support for metadata, and that has been my experience. When doing export multiple for an LP I open the metadata editor and set the common fields (Artist Name, Album Title), then let Audacity fill in Track Title and Track number. iTunes picks these up, possibly saving me a bit of time.
-- Bill
waxcylinder
Re: Track Labels
Post by waxcylinder » Mon Dec 21, 2009 5:38 pm
Bill,
Ah, I see - but am I right in assuming that there is theoretically no difference in audio quality between AIF and WAV?
And further does iTunes handle them both equally in terms of Audio quality?
Thanks,
billw58
Re: Track Labels
Post by billw58 » Mon Dec 21, 2009 5:44 pm
waxcylinder wrote: Ah, I see - but am I right in assuming that there is theoretically no difference in audio quality between AIF and WAV?
AFAIK, yes.
-- Bill
iew
Re: Track Labels
Post by iew » Tue Dec 22, 2009 4:21 pm
I don't know what I am doing wrong. I went back and loaded the previous version of Audacity and I get the same thing.
1. Recorded.
2. Added song name.
3. exported an AIFF File to desktop.
3. Added to ITune Library.
The whole file appears no labels or separation. I have done this before with no problem what have I forgot to do???????
waxcylinder
Re: Track Labels
Post by waxcylinder » Tue Dec 22, 2009 5:03 pm
You need to be using Export Multiple and not just the simple Export.
See: http://wiki.audacityteam.org/index.php? ... ate_tracks
iew
Re: Track Labels
Post by iew » Tue Dec 22, 2009 6:04 pm
Ok, I exported multiples and ended up with multiple AIFF files. How do you consolidate and put in ITunes all at one time? I know I've done this before, just can't remember how.
