I just bought an ION iTT usb turnable and recorded a test album. My issue is that even with the click & pop and noise removal filters I still had a lot of clicks & pops. Being a novise at this, are there any good tutorials on getting the best recordings from vinyl?
Thanks!
recording vinyl
Re: recording vinyl
You will not get rid of all the clicks pops and noise without loosing a lot of the sound quality.
Don't use the filters at aggressive levels on the whole recording - If you want to process the entire recording, use modest settings. Any parts that need cleaning up further, zoom in and select the specific part - in some cases you may need to zoom into a single click and adjust the pop filter to higher settings (then repeat for each pop).
Scratch removal is never perfect, and how good or bad it is depends on many things, including the quality of the original recording, the quality of your recording, the quality of the recording equipment, and how much time you are prepared to spend on it.
Experimentation is the best method - and the trade-off between noise and loss of fidelity is a personal choice.
Re: recording vinyl
Thank you for your input. I'll have to experiment a bit more to see what I'm most comfortable with. Gee, too bad there isn't that magic button that makes everything perfect like the one on the computer at work.
Re: recording vinyl
The "Noise Removal" and "Click Removal" effects are fairly magical
It may be that you are not getting the most out of them - difficult to tell without hearing the "before" and "after".
Any chance that you could upload a couple of samples and post links, I'd be happy to have a go myself and send you the settings that I find work best.
[EDIT] You may find this post useful: http://audacityteam.org/forum/viewtopic ... =713#p2419
