How to mix files on 1.3.9?
I just downloaded audacity and Im trying to figure out how to mix two songs or more together? DO any of you know how to do that?
billw58
Re: How to mix files on 1.3.9?
First of all, you're in the wrong forum. Maybe one of the admins can move this to the 1.3.x forum, where it might get more attention.
Second, what do mean by <<mix two songs or more together>>?
If you mean crossfading a number of songs to create a seamless mix, just put each song on its own stereo track then use the time shift tool to shove them around until you get a crossfade you like. You can use the Fade Out and Fade In effects if you like. When you're done export it to an MP3 or AIFF file so you can play it in iTunes or burn it to a CD. You'll end up with one long track with all the songs mixed.
If you're looking to do something different, please be more specific.
Also have a look at:
http://manual.audacityteam.org/index.ph ... =Main_Page
http://manual.audacityteam.org/index.ph ... _and_Clips
http://manual.audacityteam.org/index.ph ... ls_Toolbar
-- Bill
-- Bill
Reason: Moved to 1.3 section
So the answer is yes.
billw58
Dizzy asked me by PM: "thank you for answering bill but I have one question yes I mean mixing songs together and said "just put each song on its own stereo track then use the time shift tool to shove them" do you think you can clarify that more? Like what do you mean its own stereo track?"
Dizzy:
You really need to spend a few minutes reading the manual. http://manual.audacityteam.org/index.ph ... dio_Tracks
Each time you import a song Audacity will create a new stereo track for that song. When you play back the project all the tracks are mixed together. When you export your project (to MP3 or AIFF) the tracks are mixed together and the resulting file will sound just like what you heard when you were playing it back.
Just play around a bit and it will start to make sense.
If you need help getting songs off of CD: http://manual.audacityteam.org/index.ph ... o_CDs#OS_X
-- Bill
Dizzy:
-- Bill
