"Could not open MP3 encoding library."
Tony33
Post by Tony33 » Thu May 14, 2009 4:23 am
I know this topic has been discussed before, but I'm asking a slightly different question....
I've been using Audacity 1.3.6 for quite some time on a computer running XP Pro, and haven't encountered any problems. Most of my projects are exported as mp3's.
I wanted to try 1.3.7, and thought it best to uninstall 1.3.6 beforehand, which I did.
I downloaded 1.3.7 and the latest version of Lame (3.98.2) and parked it in the Audacity 1.3 Beta (Unicode) folder. When prompted for the location of the Lame encoder, I make sure the location is correct.
However, when I click "ok" to export a project, I get the message "Could not open MP3 encoding library."
I thought that if 1.3.7 was too unreliable, I could download 1.3.6 again (and the appropriate Lame) and continue on as before. I should have confirmed that first, because now I can't find 1.3.6 on the Audacity website!
I hope someone out there can help me recover from this .... I rely on Audacity a lot!
Thanks in advance,
Tony Allen in Saskatoon Canada
waxcylinder
Re: "Could not open MP3 encoding library."
Post by waxcylinder » Thu May 14, 2009 9:25 am
This sticky thread should help you: http://audacityteam.org/forum/viewtopic.php?f=16&t=9175
Tony33
Post by Tony33 » Fri May 15, 2009 5:25 am
Thanks for replying! I did download the latest Lame, right after I downloaded Audacity 1.3.7, so I think there must be some other explanation. That's why I was asking if there was any source for downloading the 1.3.6 .exe file again (and the appropriate older Lame version if necessary) so I could go back to using it. Of course, I realize I should have had the good sense to keep the original download .exe of 1.3.6 and the Lame I was using with it, on my computer! Had I done so, the recovery would be easy.
Cheeers,
Tony
waxcylinder
Post by waxcylinder » Fri May 15, 2009 9:36 am
If you really can't get it to work (I know from reading other threads that lately there have been some conflicts bewteen Audacity and Lame versions - but I thought the developers had fixed all that) - then a suitable workaround would be to export as WAV and then find yourself a standalone WAV to MP3 converter. A quick google of t'interweb should probably find you a free one - you can even get iTunes (free to download) to do it for you, but it's a bit fiddly.
intristin
Post by intristin » Thu Jun 11, 2009 7:56 am
I can't get this to work either. I have spent the last 3 hours reading post after post and trying this and that. The latest lame download must be bugged. This is very frustrating. :cry:
intristin
Post by intristin » Thu Jun 11, 2009 8:20 am
Ok, I fixed the problem by installing .net framework. I was installing it for another program but noticed this one started working correctly after that. Not sure if it had anything to do with it or if it was just a fluke.
