How to Remove Audicity Beta Program?
scotty
Post by scotty » Mon May 11, 2009 1:07 pm
I downloaded Audicity and Audicity Beta this weekend for my daughter, in addition to Lame. Something viral happened and crashed my system. I'm trying to do a PC recover now, but can't seem to remove or de-install these programs. They do not show up on my add/delete programs list. Suggestions are appreciated on how to remove these programs from my PC. :(
waxcylinder
Re: How to Remove Audicity Beta Program?
Post by waxcylinder » Mon May 11, 2009 1:38 pm
If you can't see it in the installed programs list, then you may find a little utilty that you can download from Microsoft useful - it's called Windows Install Clean Up (I had to download recently to clean up a failed Qucktime/iTunes update installation when it all go out of kilter).
Note that to totally remove 1.3.x you will also need to remove any preferences files that have been created (one per user of Audacity) - they are called audacity.cfg.
