Audacity cannot open MP3 encoder
acdguitar
Post by acdguitar » Sun May 10, 2009 4:38 pm
Before I get a reply that I don't need:
Yes, I have followed all instructions.
Yes, I am using the Beta.
Yes, I have the newest version of the Lame MP3 encoder.
Now onto my problem:
I have installed everything properly. I run the file, which creates a folder in my computer holding the lame encoder. It doesn't have a zipper on it, so I assume that it's unzipped. My audacity will not recognize that the file even exists. When I export something, I receive the error message "Could not open MP3 encoding library!" I've tried to search the forums to find an answer, but I seem to be out of luck. Perhaps I'm overlooking the post. Please either answer this question or direct me to the post that answers this. Thank you.
Re: Audacity cannot open MP3 encoder
Post by steve » Sun May 10, 2009 11:42 pm
acdguitar wrote:Yes, I have followed all instructions.....
These are the most up to date instructions and links:
http://audacityteam.org/forum/viewtopic.php?f=16&t=9175
acdguitar
Post by acdguitar » Mon May 11, 2009 11:18 pm
thank you. unfortunately for me, i have already seen this and it has not helped.
waxcylinder
Post by waxcylinder » Tue May 12, 2009 8:55 am
A workaround would be to export as WAV files and then find a standalone WAV to MP3 converter (you should find a free one with a quick googleof t'interweb - you can even do it in iTunes, but it's a bit fiddly).
acdguitar
Post by acdguitar » Wed May 13, 2009 6:50 pm
Hey thanks for the advice! I guess I have no other choice. haha
