Trouble with getting LAME Encoder
JMos24h23645
Post by JMos24h23645 » Fri May 01, 2009 6:09 am
Good morning,
I was attempting to get the LAME encoder this morning from the site linked from Audacity.sourceforge.net. However, it's flat inaccessible, at least the LAME encoder download page is. The rest of that site works fine as normal. Does the person who runs that domain know of it, and if so, how long until it returns. The reason I ask is I need the encoder to export as MP3 for my work as a DJ for an online station.
Thanks,
Jeremy Moses aka JMos24
Re: Trouble with getting LAME Encoder
Post by kozikowski » Fri May 01, 2009 6:26 am
You don't need Audacity to create MP3 files. You can Export a WAV file and convert it in Super and you can set up iTunes Import to create MP3s for free. That should get you rolling while you/we figure out the lame library problem.
Beta-Looker
Post by Beta-Looker » Sat May 02, 2009 1:24 am
I go to this link:
http://lame.buanzo.com.ar/
I click on this link phrase:
http://lame.buanzo.com.ar/Lame_v3.98.2_ ... indows.exe
Iend up at the link with this message:
403 - Forbidden
Please fix this as soon as possible.
I would sure like to start beta testing the new version.
coonsanders
Post by coonsanders » Tue May 19, 2009 7:08 pm
hi
i too have a problem with the encoader....i did all the directions to get it...but its not listed in the tool bar(you know export as wav or mp3 files etc....)what can i do?and also how do i then export them?thanks
lenny
Blarg
Post by Blarg » Sat May 23, 2009 9:53 pm
The problem is lame_enc.dll recognition in Audicity 1.3.7 is effed up. It will only accept their version of the dll. If you try a dll from another place that is clearly labeled 3.98.2, Audicity will only recognize it as 3.98 and popup an error message. And honestly, do you really need an installer? I have no idea why they even did that. Here's the dll file: http://lame.buanzo.com.ar/lame_enc.dll . Just stick it in your Audacity folder and browse for it.
coonsanders
Post by coonsanders » Sun May 24, 2009 10:01 am
hi
i seem to config the lame ok...thanks 4 the info...
coonsanders
