Recording pause tab
bert44
Recording pause tab
Post by bert44 » Thu Apr 23, 2009 11:39 pm
I am using Audacity 1.3.7 with Windows XP to transfer LP's and Cassettes on CD. Wondering why the pause button will not work in the record mode. Thanks.
waxcylinder
Re: Recording pause tab
Post by waxcylinder » Fri Apr 24, 2009 9:49 am
Just tested on my 1.3.7 also running on XP-HE - the Pause button works fine, so I'm puzzled :?
Have you also tried using the keyboard shortcut the P key to pause ?
bert44
Post by bert44 » Fri Apr 24, 2009 12:49 pm
WC, Thanks for your help. Just tried the P tab and no luck. No way I can pause in the record mode but when I stop the recording and play it back the pause workes fine ??? All I can do is record side A of a cassette then switch to B and then go back and edit the pause gap.
waxcylinder
Post by waxcylinder » Fri Apr 24, 2009 4:32 pm
No, you can Stop the recording after side 1 and then when you have turned over and are ready to record again press Shift+Record or Shift+R - the recording will then restart in the same track just where you left off.
bert44
Post by bert44 » Fri Apr 24, 2009 6:24 pm
Thanks so much for the help. Works fine. I was using the stop then record button again getting two new tracks.
