I am converting old LP's to mp3.
I have a symphony concert that takes up a whole LP, and when I do the one side of the LP, (about 30 minutes) and export it to mp3, only an SKF file is exported. I thought this must be as a result of the file size?
When I convert short "ordinary" tracks, it works fine.
Please help...
Only SKF file saved on long recording
Re: Only SKF file saved on long recording
I now have another problem.
When I record, the waves are almost flat, and seem terribly compressed. I am a total newbie at this. I have tried uninstalling and reinstalling, but it stays the same.
You have probably not received a reply because "skf" is not an audacity file type. What makes you think that Audacity has created an skf file?
