That is sufficient to say that Audacity is running nicely on your computer.LMPeach01 wrote:s this sufficient to tell you what you need to know
I hope you were paying attention to what you did, because I'm going to ask a few questions about it (don't worry, it's not a test
1) What sample rate were you recording at?
2) What do you have the bit depth set at?
3) Were these mono or stereo tracks?
4) When you import that MP3 track, what is the sample rate, bit depth and is it stereo or mono?
A second test:
Follow exactly the same procedure that enables you to record 16 vocal tracks, but after recording the first vocal track, Import the MP3 , then play - if it plays OK, continue recording other tracks.
