Hi, again..
Gale Andrews wrote:OK, though I would be interested to know whether
lame_enc.dll 3.98.2 will encode for you in 1.2.6. It is supposed to, and does here. Can you let us know?
Same story. Removed all traces of 1.3.7 (1.3.8 alpha), audacity.cfg, lame_enc.dll, etc -- nothing on the disk. Installed the 'standard' 1.2.6 version and retrieved my 3.97 and your 3.98.2 versions of lame_enc.dll.
Place the 3.97 lame_enc.dll into folders, not immediately recognized... but when browsed and loaded through 'Edit > Preferences", 3.97 library is identified, loaded and works Ok.
Using 3.98.3, nothing works. Not immediately recognized... when browsed to and loaded it remains unrecognized/no library found after loading. Naturally, no MP3 encoding is available.
So, it would seem we're talking about the 3.98.2 LAME may not be built to suit my Windows... hmm...
[...thinks...]
Now, I've just tried installing 1.2.6 and LAME 3.98 on my 'real' PC (Win XP Pro SP2) and guess what - this installation works Ok. Loads 3.98, recognizes it... and uses it on encoding. Shall I bite the bullet..?...
Yup. Installing 1.3.7 Beta and the 3.98.2 lame_enc.dll everything works as advertised; finds/identifies the library Ok, encodes clean, etc.
So, it looks like there's something with the un-patched/raw Windows (Win XP Pro, no service packs, no patches) that's causing the grief... or does Audacity and/or lame_enc.dll require .NET Framework to be installed?
Now... What to do about upgrading that silly Windows version... hmm... Sheesh, I don't want to do ANOTHER rebuild of that silly PC -- 2x Windows, 4x Linux + embedded VMS... let alone all the music software... *Dang*.
