any way to change bitrate of MP3 export?
vinceshaw
Post by vinceshaw » Sun Mar 29, 2009 11:38 am
I am working on voice material with original 64 bit. After finishing edit, the exported mp3 is alway 128 bit, waste of resources. I went through all the configure settings and manuals, no clue founded yet.
Wonder is it possible?
Any help is appreciated.
Vince
Re: any way to change bitrate of MP3 export?
Post by kozikowski » Sun Mar 29, 2009 7:49 pm
Correct me, but Audacity 1.3 has the ability to set the MP3 bitrate at export. Open up the Options panel in the export window.
vinceshaw
Post by vinceshaw » Mon Mar 30, 2009 7:27 pm
Thanks, Koz.
I missed the obvious. Went through all the main settings, neglected the Option button in the place usually for file naming. A lesson: never take any thing for granted.
Vince
Elad
Post by Elad » Tue May 12, 2009 4:17 am
I know this an old post, but I was unable to find this option till I went searching the forums and found this post.
Seems to be an odd place for this option.
Been better in the EXPORT tab area...
hrundi
Post by hrundi » Thu Jun 18, 2009 10:48 pm
Sorry, I have the same problem, and I can't find the Export window.
the only Export button I could find (in the file menu) is grayed out when I want to apply chain, and that's why I installed the beta in the first place
on the other hand, when I do import a file firs and then select Export I get this
Post by kozikowski » Thu Jun 18, 2009 11:10 pm
From the pictures, Audacity will not Export anything unless there is a show on the timeline to Export. It will Save A Project because a Project is an editorial environment, not a sound file.
I "OK" my way around the metadata editor. I don't think I've ever typed anything in those boxes. I think there is a preference setting where the dialog doesn't show up at all which is how the older Audacity worked.
hrundi
Post by hrundi » Thu Jun 18, 2009 11:38 pm
Thanks, I got it now.
