Problems with headphones (windows vista)
Iconico
Post by Iconico » Sun Mar 15, 2009 4:49 pm
Title says it really, the problem is that when i listen to audio off a site ( you tube for example ) the sound plays but VERY quiet how do i turn it up? looked around control panel etc for it but i cant find and also im new to vista. Will be gratefull if someone can help
Thanks,
Iconico ;)
Re: Problems with headphones (windows vista)
Post by Gale Andrews » Thu Mar 19, 2009 7:47 am
Iconico wrote:Title says it really, the problem is that when i listen to audio off a site ( you tube for example ) the sound plays but VERY quiet how do i turn it up?
Right-click over the speaker icon in the System Tray > Playback Devices. Or click Start > Control Panel > Hardware and Sound > Sound (if you're using "Classic View" there's a direct link to "Sound" in the Control Panel), then click on the "Playback" tab. Right-click over the sound device your headphones are plugged into > Properties, click the "Levels" tab and turn up the slider at the top (probably says "Speakers" or "Headphones").
