I think that we may have got somewhat distracted from the original question.
Although "short recording > OK / long recording > stuttering" is usually indicative of fragmentation or other drive access speed issues, we seem to have pretty well eliminated such possibilities.
Looking back to the first page of this topic....
leChef1001 wrote:
My system:
Vista x64 SP1,
8 GB Ram,
lots of free disc space,
Soundblaster X-Fi Xtreme Music set to audio creation mode,
latest drivers installed
Sounds like a good set-up, and with further details supplied later, it should work brilliantly with Audacity. The one doubt that I have about this set-up is that there were known incompatibility problems with the X-Fi series and 64 bit Vista with 4GB or more RAM up until recently (if I recall correctly ~ 2008). The latest driver updates were supposed to fix these issues. (I wonder how much these updated drivers have been tested on recordings in excess of 6:45:47.5 duration).
leChef1001 wrote:Aftrer trimming the project to the point where the stuttering starts, the project folder contains 8192 file with an overall size of 8,12 GB.
The number 8192 doesn't seem random to me....
I get the impression that you have tested this quite thoroughly, and no, 8192 does not seem "random" (128 x 64, or 2^13).
I don't know how practical this is for your situation, but I think that what I would be trying at this stage is temporarily replace the X-Fi sound card with some other sound card, purely for testing purposes. If the issue than goes away, then that would confirm a problem with the sound card (almost certainly the sound card driver). My guess at this stage is that the sound card driver (under Vista 64) is the problem, and since the X-Fi Extreme music is now discontinued, the chances of a fix from Creative are probably not that good. However, OEM versions of this sound card are still widely available, so even if this does prove to be the problem, there is at least a chance that alternative drivers may be available.
As indicated earlier in this thread, there is still an issue that an 8GB file can not be Exported as a single WAV file (because the format does not support greater than 4GB), so I would probably not be making such long recordings anyway, though that does of course depend on what you are using Audacity for.
Sorry for the absence of answers - perhaps someone else has some other ideas?
