1.3.7: file export sometimes fails (creates small file)
roga
Post by roga » Thu Mar 05, 2009 9:07 am
Sometime on file export -> mp3 a very small file is created which does not contain the data
If I repeat the process then it works properly
also (on another point) 1.3.7 +the only lame it will work with seems to create larger size files than previously using standard preset
R
Re: 1.3.7: file export sometimes fails (creates small file)
Post by steve » Sat Mar 07, 2009 2:20 pm
roga wrote:Sometime on file export -> mp3 a very small file is created which does not contain the data
I'm unable to reproduce that problem.
roga wrote:also (on another point) 1.3.7 +the only lame it will work with seems to create larger size files than previously using standard preset
The old version would frequently (incorrectly) produce MP3's at 128kbps CBR when it was set to produce "Standard" quality (170-210 kbps VBR).
