playback
bemahler
playback
Post by bemahler » Mon Mar 02, 2009 5:27 pm
Having just bought a Jammgear usb deck and being able to transfare lp's to my computer using Vista, I am finding that the recored sound is in mono, please help.
waxcylinder
Re: playback
Post by waxcylinder » Mon Mar 02, 2009 6:01 pm
See this article from the Audacity Wiki: http://audacityteam.org/wiki/index.php? ... _turntable
And be aware tha Audacity OOTB defaults to mono - go to Edit > Preference > Audio I/O and set the Recording Channels at the top right of the dialog box to 2 (stereo)
bemahler
Re: playback
Post by bemahler » Mon Mar 02, 2009 8:02 pm
Thanks, had a look at the settings,changed to what you said, tried again,still playing back mono, help!
waxcylinder
Re: playback
Post by waxcylinder » Tue Mar 03, 2009 11:07 am
Possibly a hardware fault on the deck or it's on-board soundcard or USB services. Are there any leads you can swap to test this out? From looking at your deck on t'interweb there appear to be RCA outputs supplied with this - if you plug these to a hi-fi or mini system do you still get mono - or do you get stereo?
bemahler
Re: playback
Post by bemahler » Tue Mar 03, 2009 2:52 pm
Just got home tried it on my stereo perfect stereo, so problem some where else.
waxcylinder
Re: playback
Post by waxcylinder » Tue Mar 03, 2009 2:58 pm
So this points to a fault on the ADC (soundcard) in the TT or the USB services. Just try wiggling the SB connector, or try a different USB port.
Since you are getting stereo out of the RCA outputs, you could try connecting these to the line in on your PC (you will neeed an RCA to 3.5mm stereo min-jack lead). Do not use the Mic in as it will probably overload it. You will also need to switch your deck to Line Level output (not phono) - this will use the pre-amp embedded in the TT and if you still don't get stereo this will point to the pre-amp being at fault.
bemahler
Re: playback
Post by bemahler » Tue Mar 03, 2009 4:13 pm
Have spoken to Acer and they have said that I need to speak to Audacity about downloading other softwear that will enable me to play back in stereo.
