records
PENNYPOMBERT2
records
Post by PENNYPOMBERT2 » Mon Mar 02, 2009 12:39 am
I have had a problem with playing records. A little hard to explain I was wondering if anybody else has had the same problem and if it can be remedied. Some records won't play right to the end the needle arm lifts up just before the end of a song and goes over to the arm rest like the records finished. E :twisted: specially in long play records. I have a forty-five that has done it to. Don't want record a song with the end of it chopped off.
Re: records
Post by kozikowski » Mon Mar 02, 2009 5:23 am
There have been other complaints about that. The trigger that senses the lead-out groove on records is broken or badly adjusted. Go read your warranty and see if that kind of damage is covered. We can do nothing for you.
