How to make a CD?
chopin2989
How to make a CD?
Post by chopin2989 » Sun Mar 01, 2009 10:52 pm
Hi guys,Im a new man here.I use 1.3 to record my music.the file is .aud. How can I transfer this to .wav ? because I want to burn my music in CD.
Thank you very much!
allencmcbride
Re: How to make a CD?
Post by allencmcbride » Mon Mar 02, 2009 3:40 am
Under the File menu, select Export. You'll be prompted for any metadata you want to enter. Then you can choose a filename and export format. Choose WAV from the drop-down menu. (If you're using earlier than 1.3.7, the metadata prompt comes after you choose a filename.) --Allen
