Recording to laptop using usb with preamp input
bedavid2
Post by bedavid2 » Fri Jan 30, 2009 7:02 am
I have a HP laptop. I used the microphone input on my laptop to record mp3 from turntable. I am getting background noise.
I would like to use the usb port and Audacity. Will this software recognize the usb connection.
Re: Recording to laptop using usb with preamp input
Post by steve » Fri Jan 30, 2009 1:22 pm
Please state if you are using Windows, Mac or Linux and which version of Audacity so that I can move this post to the correct message board.
bedavid2
Post by bedavid2 » Fri Jan 30, 2009 5:17 pm
I'm using Windows XP and Audacity 1.3.7
Post by steve » Fri Jan 30, 2009 5:36 pm
bedavid2 wrote:I have a HP laptop. I used the microphone input on my laptop to record mp3 from turntable. I am getting background noise.
That's not unusual, most PC laptops have very poor quality microphone inputs.
bedavid2 wrote:I would like to use the usb port and Audacity.
You can use an external audio device with Audacity, as long as it is correctly installed and working in Windows. Some USB turntables have proved to be bothersome for many users, causing drop-outs and other failures with audio capture. External sound cards on the other hand are generally quite reliable.
I presume we are talking "vinyl" here? If your turntable does not have a built in phono pre-amp, it would be best to use an external sound card that has a built in pre-amp, for example: http://www.soundonsound.com/sos/may06/a ... noplus.htm
bedavid2
looking for a external sound card
Post by bedavid2 » Sat Jan 31, 2009 6:58 am
I'm looking for a external sound card for my hp laptop, windows xp, to record vinyl to mp3
Post by steve » Sat Jan 31, 2009 2:08 pm
stevethefiddle wrote:If your turntable does not have a built in phono pre-amp, it would be best to use an external sound card that has a built in pre-amp, for example: http://www.soundonsound.com/sos/may06/a ... noplus.htm
