darobin wrote:No the problem is that when you go to
EXPORT the file there is no choicel mp3
wav in any window -- you only see the Tag
/Labeling window.... The problem with mp3 encoding with 1.3.7
is still there -- even with the RC2 version now
available. . . .
1.3.7 *is* out
1.3.7 Beta is most definitely out. The Windows builds are here:
http://audacityteam.org/download/beta_windows#recdown
If it still says 1.3.6, then the page is cached - just refresh it. We recommend everyone to subscribe to receive occasional e-mails from us when we release new versions of Audacity. To subscribe, go to the bottom of our home page:
http://audacityteam.org/#announce
enter your e-mail address and click "Add".
Metadata Editor
The Metadata Editor now comes first before choosing the file name or the export format:
(a) because we thought that was more logical
(b) because it was the simplest fix to an overwrite problem we had
This problem occurred if you import a WAV file reading directly from the disc (which is the default choice on the Import / Export tab of Preferences), then export it to the same file, so overwriting it. If you do that in 1.3.6 (where the Metadata Editor comes *after* choosing the file name and the overwrite prompt), then cancel the Metadata Editor (so cancelling the export), the file you imported is deleted. Also, the project is silenced (because the file it was reading from no longer exists).
We still have this overwrite problem with export multiple, so the advice is if you want to overwrite uncompressed files, set the Import / Export preference to "make a copy".
If we get majority feedback that the Metadata Editor coming before the "Export File" dialogue is confusing, then we can probably change this and defer overwriting of files until after the metadata is confirmed. However, the metadata editor does not stop you getting to the Export File dialogue - just OK the Metadata Editor, or stop it popping up altogether by unchecking "Show Metadata Editor prior to export step" in the Import / Export Preferences .
AVS Editor
As regards AVS Editor on our SourceForge downloads pages, please see:
http://www.audacityteam.org/forum/viewt ... 500#p34381
