batch options in preferences
I was reading the website and saw that there were options for doing batch conversions. I went to the preferences screen and three is not "batch" option, same for under the file menu. Was the batch features only in a specific version?
Re: batch options in preferences
Audacity uses "chains" of commands which you can create, or edit to suit your needs.
Look in "File menu" "Edit Chains" to create or edit chains.
"File menu > Apply Chain..." to apply the commands to a single file, or multiple files. (batch process)
