Have just installed 1.3.6 from 1.3.4 and noticed that almost all the Effect are missing from the list including for example Compressor, Echo and Repeat.
If I re-install 1.3.4 all the effects are back again.
I am installing in the same directory location - i.e overwriting the existing installation both ways and have done so several times to be certain. Have also checked the Plug_Ins folder but the Effects I refer to are built-in ones I think in 1.3.4
Have I missed something that happened in 1.3.5 and more to the point can I still use 1.3.6 and later with all the Effects?
Is 1.3.5 still available for download?
Thanks.
1.3.6 Effects list
waxcylinder
Re: 1.3.6 Effects list
In 1.3.6 the effects are structured into sub-lists - hover over an item in a list to see the sub-list.
I had the same problem a while back. For me, it was the "CleanSpeech" user interface that was clicked in the preference panel.
Check to make sure that "CleanSpeech" is unclicked.
Edit > Preferences > Interface Tab. At the bottom is the check box for the CleanSpeech user interface.
CleanSpeech is extremely useful for those who do voice-based audio blogs, as it, automatically, applies speech enhancing filters to the recorded sound track, however, it is not that good for music.
