markh_tampa
Post
by markh_tampa » Thu Jan 08, 2009 3:26 pm
I am a veteran Audacity user... mostly on XP.
I tried this same task on 1.26, 1.34 and 1.36 --- no go anywhere.
(and yes, I installed the Lame dll)
Anytime I try to export as MP3, the app just locks up.
Have to kill it thru Task Manager.
- Site Admin
Post
by steve » Thu Jan 08, 2009 5:53 pm
I don't have Vista, so I can't try it, but it may be worth trying a different version of Lame - do you have the latest version from the main Audacity web site?
NineEyes
Post
by NineEyes » Thu Jan 08, 2009 6:00 pm
Look, a Vista user!!
This isn't Vista64, right? I've exported MP3s using 1.2.6 on Vista32 (home premium)....but it's been a while, so I'll try it again when I get home tonight and report back just to be sure. I'll also give it a shot on 1.3.6.
If you have time, I'd appreciate it if you'd try this Vista experiment (the second one):
http://audacityteam.org/forum/viewtopic ... =10#p32817
and report your results on that thread.
markh_tampa
Post
by markh_tampa » Thu Jan 08, 2009 6:17 pm
I will try a different LAME... this is 397, but I will look for some others...
Vista x86 (Home Premium)
Brand new PC... just 5 weeks old.
Intel Q6600 Quad Core with 4 GB of RAM.
Over a TB of disk space.
I will also try the experiment on the other thread.
Thanks,
Mark
NineEyes
Post
by NineEyes » Fri Jan 09, 2009 3:44 am
markh_tampa wrote:Vista x86 (Home Premium)
That's a sweet sounding rig.
Anyway, I did try exporting to mp3 (single tracks, and multiple tracks) in 1.2.6 and in 1.3.6 and it never failed. I have Lame v3.97 and used a bitrate of 192kbps. My project rates were all 44100Hz.
boogiemann
Post
by boogiemann » Tue Jan 20, 2009 9:17 pm
I have Vista Business 32-bit. I am using 1.36 Beta. For some reason, I was able to export MP3's about 1 month ago. Today, I get the same hanging problem. I even get the same hang when I try to export to WAV. The only thing I am able to save is an Audacity AU project. Anyone out there might be able to help?
markh_tampa
Post
by markh_tampa » Wed Jan 21, 2009 8:22 pm
Yeah, I found a workaround... I ditched Audacity, and went back to Cool Edit Pro.
At least it allows me to chop my MP3s and actually SAVE them again.
- Site Admin
Post
by steve » Thu Jan 22, 2009 12:04 am
markh_tampa wrote:Okay... let me clarify.
I cannot export as ANYTHING. No WAV, no MP3, no nothing.
That's quite a crucial bit of information. I'm surprised you didn't think of including it in this topic.
