Preferences????
Preferences????
When i go to Edit > Preferences...It crashes Audacity. Here is a pic
http://i39.tinypic.com/jv6sl5.png
im using Windows Vista Home Basic. My computer meets all the requirements (above and beyond)
Re: Preferences????
While you have it open, can you capture anything and play simple sounds?
http://www.kozco.com/tech/soundtests.html
Pull down any of the three piano clips and see if they play. They're really short and guaranteed correct.
Do you have a lot of External Stuff hanging from your machine? USB Turntable? USB Sound Production Equipment? Video equipment? Skype?
Re: Preferences????
That will happen if there are no recording devices available. Go into the Windows control panel and make sure that there is an available recording device. See here for details: http://audacityteam.org/wiki/index.php? ... ng_devices
Re: Preferences????
No...it crashes the application...I cant do anything with it, except clike the "Yes" button on the message that comes up saying that it crashed.....Now, if i DON'T click preferences, and try to get into that menu...I can do anything with it. everything works, i tried a lot of stuff with it, but the second i go to Edit > Preferences, to customize Audacity to fit my needs, it just crashes.
no, i don't have any external devices hooked up to my computer at all.
Well, i dont have any recording devices available (no microphone, or anything like that) you mean i cant use adacity without a recording device????
Re: Preferences????
NEVER MIND.....it works now.....Thank you, stevethefiddle. That helped alot.....Its fixed now
Re: Preferences????
Care to tell us how?Zach610 wrote:NEVER MIND.....it works now.....Thank you, stevethefiddle. That helped alot.....Its fixed now
(I don't have Vista, but a lot of other forum users do)
Re: Preferences????
stevethefiddle wrote:Care to tell us how?Zach610 wrote:NEVER MIND.....it works now.....Thank you, stevethefiddle. That helped alot.....Its fixed now
Well, i went to Control Panel > Sound > Recording > And enabled the recording device....
Here is a pic, of what i mean http://i41.tinypic.com/zwi26q.png
Re: Preferences????
Thanks for the confirmation Zach
