Effects Plug-Ins not showing up.
Re: Effects Plug-Ins not showing up.
Post by steve » Mon Dec 29, 2008 10:39 pm
I've not got a Windows machine handy at the moment, but you should have more than that. There should be the "Change Speed"/Tempo/Pitch effects for a start.
We need accurate detail now: Which version of Audacity do you have (look in the "About" part of the Help menu)
Which version of Windows?
What is the exact path to your Audacity program folder?
What is the exact path to the plug-ins folder?
It may be a bit tricky, but can you also take a screen shot of the Effects menu? (the "print screen" button on your keyboard should capture the screen to the clipboard so that you can paste it into any graphics editing program - trim it down, then upload it to the forum - details here: http://audacityteam.org/forum/viewtopic.php?f=32&t=7889 )
skey
Post by skey » Mon Dec 29, 2008 11:44 pm
stevethefiddle wrote:
skey wrote:the plugins are in C: > Program Files > Audacity > Plugins
That could be the problem - I don't think that is the default directory for Audacity 1.3.6
It should be something like:
C: Program FilesAudacity 1.3 Beta (Unicode)Plug-Ins
That worked for me, thank you.
tophtml
Post by tophtml » Tue Dec 30, 2008 1:16 am
Oddly enough, all of the plug ins show up in 1.2, just not 1.3, even though they were all installed in their respective plug-in directories.
Audacity 1.2:
C:Program FilesAudacityPlug-Ins
Audacity 1.3:
C:Program FilesAudacity 1.3 Beta (Unicode)Plug-Ins
Wierd . . .
tophtml
Post by tophtml » Tue Dec 30, 2008 1:45 am
I finally found out what was happening. I had to access "preferences" > interface and unclick "CleanSpeech Mode" at the bottom. It all works now.
I just have to find out what CleanSpeech really does.
It's playtime folks!
tophtml
Post by tophtml » Tue Dec 30, 2008 1:53 pm
I do some podcasting and I tried "cleanspeech" on an mp3 podcast file. It is great, essentially a macro that applies a number of preset filters to clean up podcast type files. It works great and saves me the time of having to apply filters manually.
Great stuff.
alboy
Post by alboy » Fri Jan 23, 2009 11:52 am
tophtml wrote:I finally found out what was happening. I had to access "preferences" > interface and unclick "CleanSpeech Mode" at the bottom. It all works now.
Im having same trouble and will try your tip. Many thanks. Why doesnt someone put a simple to use Audacity user guide? Or would it be 4000 pages long?
Post by steve » Fri Jan 23, 2009 12:01 pm
alboy wrote:Why doesnt someone put a simple to use Audacity user guide? Or would it be 4000 pages long?
See the "Tips" and "Tutorials" links at the top of this page.
The 1.3/1.4 manual is not yet finished and currently runs to over 240 pages (English language version).
(mental note to self - there should perhaps be a mention of Clean Speech mode in the "Tips" section)
