Help please.
omfgitsangie
Help please.
Post by omfgitsangie » Sun Dec 21, 2008 5:16 am
Okay in my previous question I asked something about Audacity being stuck so I fixed it by uninstalling it and downloading a fresh copy of the installation and reinstalling it. Now it works, but something weird has happened and I don't know why it's happening. When I'm recording my guitar now, it doesn't sound clear, and it's only started happening when I reinstalled it. Now when I record, it records as a stereo track? Would that be the problem? And if so, how do I change it back to a (don't know what it is, just guessing) a mono track? Because it was fine when it used to record like that.
Thanks so much. Sorry, I don't really know much about this.
Re: Help please.
Post by steve » Sun Dec 21, 2008 12:23 pm
You can set the number of recording channels (1 - mono, 2 - stereo) in Audacity Preferences.
Go to the Edit menu and select Preferences
Look on the "Audio I/O" tab.
Since you had problems with your previous install, it is probably a good idea to completely reset Audacity preferences. You do this by deleting the audacity.cfg file. It is a hidden file located in:
Documents and Settings<user name>Application DataAudacity
omfgitsangie
Re: Help please.
Post by omfgitsangie » Mon Dec 22, 2008 8:02 am
Aw thank you so much. :D
