Where is the REPAIR effect in 1.3.6 ?
waxcylinder
Post by waxcylinder » Fri Dec 12, 2008 11:20 am
Ok - so in 1.3.6 we have the natty little nested dropdown segmented lists of Effects - but where oh where is the Repair effect.
I can't see it anywhere - am I missing something? Has it been dropped from the functionality?
It's one of the most important editing tools that I use .....
Windows XP-PRO fully updated by Microsoft / Audacity 1.3.6 (Unicode)
Re: Where is the REPAIR effect in 1.3.6 ?
Post by kozikowski » Sun Dec 14, 2008 1:17 am
Effect > Utility > Noise Removal > Repair.
waxcylinder
Post by waxcylinder » Mon Dec 15, 2008 1:29 pm
Hi Koz,
thanks for that (saves me going back to 1.3.5 just for the odd Repair ....)
I note from a subsequent posting by Gale that the actual layout structure of the effects may well change - what they put in 1.3.6 was just experimental - so just beware in later releases (actually IIRC you are trying 1.3.7 - is the Effecsts layout the same there?)
Post by kozikowski » Wed Dec 17, 2008 12:24 am
I do have an install of 1.3.7 under Leopard, OS-X 10.5.5, yes. I just needed the excuse to go out and buy Leopard and install it somewhere. I also have a separate partition on the same drive with Leopard and 1.3.6. The main machine is still under Tiger and features 1.2.5 (Intel version) and 1.3.5 which I kind of like.
Leopard was the first time Apple got very serious about upgrades and patches. I installed it and told it to go look for patches and didn't get the machine back for several hours. And I did two installs....
Good thing I have two machines.
waxcylinder
Post by waxcylinder » Wed Dec 17, 2008 9:46 am
kozikowski wrote:Leopard was the first time Apple got very serious about upgrades and patches. I installed it and told it to go look for patches and didn't get the machine back for several hours.....
yesss.. even good ol' iTunes can take a fair old while to upload and install an update.
And yes two machines is good in that circumstance - I'm glad I have the laptop as well as the desktop so Apple can grind on them at different times.
