Need help!
Need help!
I've got two questions!
1. Why can't I remove vocals from a MP3 track converted from a video file?
2. When I want to perform a voice-over, the track that I'm dubbing can't be heard during the dubbing, why?
Re: Need help!
<<<Why can't I remove vocals from a MP3 track converted from a video file?>>>
MP3 audio format damages the sound a little and that damage tends to make vocal removal harder. We tell people to do production and effects from a WAV file, not MP3.
If you got the sound track from an on-line server or company, chances are it's in mono, not stereo. Vocal Removal doesn't work from a mono track--or a stereo track with the same show on both left and right (really, two-track mono).
<<<When I want to perform a voice-over, the track that I'm dubbing can't be heard during the dubbing, why?>>>
You may have some Audacity settings wrong. Look here:
Edit > Preferences > Audio I/O > One of those clickies on the bottom.
Re: Need help!
I converted the video file to a wav file but it's still quit when I try to remove the vocals!kozikowski wrote:<<<Why can't I remove vocals from a MP3 track converted from a video file?>>>
Re: Need help!
<<<I converted the video file to a wav file but it's still quit when I try to remove the vocals!>>>
Audacity crashes? That's not the question you asked at the top. Is that what happens?
Re: Need help!
No, I accidently wrote quit instead of quite!kozikowski wrote:<<<I converted the video file to a wav file but it's still quit when I try to remove the vocals!>>>
waxcylinder
Re: Need help!
I assume you really mean "quiet" ??simonsko wrote:No, I accidently wrote quit instead of quite!
Re: Need help!
Yes! Sorry for the typo! Well, why is it still quiet even though I'm converting the video file to a wav file?waxcylinder wrote:I assume you really mean "quiet" ??simonsko wrote:No, I accidently wrote quit instead of quite!
waxcylinder
Re: Need help!
Have you tried using the Audacity Amplify effect to boost the level of the recording ?
Re: Need help!
Yes, but that didn't help much!waxcylinder wrote:Have you tried using the Audacity Amplify effect to boost the level of the recording ?
