Can't install ffmpeg import/export
On Audacity 1.3.6
Preferences
Import/Export
I click the "ffmpeg download" button, it takes me to
http://www.audacityteam.org/manual/inde ... tallffmpeg
and then http://lame.buanzo.com.ar/ffmpeg.win32. ... encies.exe
which have extracted, as instructed, into the Audacity folder.
Then I click "find library" for ffmpeg and select the file "avformat-52.dll" which I have obtained as above.
Then a message: "Failed to find compatible FFmpeg libraries".
I am using Win2k if that is relevant.
Preferences
Import/Export
Re: Can't install ffmpeg import/export
I've got the same error message on an old windows me computer
justin.young
I have installed 1.36 on several Win 2000 PC's and can confirm that the FFMPEG plugin works on none of them and gives the "Failed to find compatible FFmpeg libraries" when you try to add them in the Audacity prefs. No such problems in Win XP, so I am assuming there is a compatibility issue with FFMEG and Win 2000.
Well, I can use the ffmpeg.exe that comes with this version to make AC3 from the command line on Win2k.justin.young wrote: I am assuming there is a compatibility issue with FFMEG and Win 2000.
Is Audacity expecting the dlls to be installed in the registry?
- Quality Assurance
This problem is caused by the checking routines which determine if the FFmpeg library is shared or static. These require a file called dbghelp.dll which is normally missing on Windows 2000 and earlier. Until we decide how to fix it in the code, I've uploaded the dll here:
http://www.gaclrecords.org.uk/dbghelp.dll
Just put it in the Audacity installation folder with the other files from the FFmpeg download. It fixes it on Windows 2000, and I assume on ME as well.
justin.young
That is excellent. Thanks for the fast reply. I will test this today.
Justin
Justin
Tested on win me and it's still not working even with the dbghelp.dll
- Quality Assurance
OK it may need some other file too, or we may decide to drop the checking routine (but note that even if we retain Windows 98/ME support through to the next stable release (1.4.0), that will likely be the last version for those two operating systems). It just becomes too much work to find fixes all the time.PerseP wrote:Tested on win me and it's still not working even with the dbghelp.dll
Anyway, could you help us by trying to load the library again? What I'd like you to do after the load fails is click Help > Show Log... and post the information that appears there. In the Debug Log window, you can either click Log > Save..., save the .txt file and upload it here as an attachment, or right-click in the debug window > Select All, then right-click > Copy, then paste the information into your post.
Thanks
The forum doesn't let atttach files it gives me the error "The extension is not allowed." so I'm pasting the log:
"no se encontró el proceso especificado" means it couldn't find the specified proccess.
[Edit] I put your file inside a [code] tag to make it easier to read and copy - stf
Code: Select all
20:22:04: Trying to load FFmpeg libraries
20:22:04: mLibAVFormatPath is not empty, = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll. Loading from it.
20:22:04: Looking up PATH...
20:22:04: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:22:04: Checking that C:Archivos de programaAudacity 1.3 Beta is in PATH...
20:22:04: not in PATH!
20:22:04: Appending ;C:Archivos de programaAudacity 1.3 Beta ...
20:22:04: Loading avformat from C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:22:05: avformat loaded successfully. Acquiring the list of modules.
20:22:07: List acquired and consists of 55 modules
20:22:07: Item 0: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETADBGHELP.DLL , name=DBGHELP.DLL
20:22:07: Item 1: path=C:WINDOWSSYSTEMVERSION.DLL , name=VERSION.DLL
20:22:07: Item 2: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVFORMAT-52.DLL , name=AVFORMAT-52.DLL
20:22:07: Item 3: path=C:WINDOWSSYSTEMAVIFIL32.DLL , name=AVIFIL32.DLL
20:22:07: Item 4: path=C:WINDOWSSYSTEMMSVFW32.DLL , name=MSVFW32.DLL
20:22:07: Item 5: path=C:WINDOWSSYSTEMWOW32.DLL , name=WOW32.DLL
20:22:07: Item 6: path=C:WINDOWSSYSTEMDCIMAN32.DLL , name=DCIMAN32.DLL
20:22:07: Item 7: path=C:WINDOWSSYSTEMCRTDLL.DLL , name=CRTDLL.DLL
20:22:07: Item 8: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVCODEC-52.DLL , name=AVCODEC-52.DLL
20:22:07: Item 9: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPTHREADGC2.DLL , name=PTHREADGC2.DLL
20:22:07: Item 10: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETALIBMP3LAME-0.DLL , name=LIBMP3LAME-0.DLL
20:22:07: Item 11: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETALIBFAAC-0.DLL , name=LIBFAAC-0.DLL
20:22:07: Item 12: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVUTIL-49.DLL , name=AVUTIL-49.DLL
20:22:07: Item 13: path=C:WINDOWSSYSTEMMSIMG32.DLL , name=MSIMG32.DLL
20:22:07: Item 14: path=C:WINDOWSSYSTEMNTDLL.DLL , name=NTDLL.DLL
20:22:07: Item 15: path=C:WINDOWSSYSTEMRICHED32.DLL , name=RICHED32.DLL
20:22:07: Item 16: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSSC4_1882.DLL , name=SC4_1882.DLL
20:22:07: Item 17: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSHARD_LIMITER_1413.DLL , name=HARD_LIMITER_1413.DLL
20:22:07: Item 18: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSGVERB_1216.DLL , name=GVERB_1216.DLL
20:22:07: Item 19: path=C:WINDOWSSYSTEMMSACM32.DLL , name=MSACM32.DLL
20:22:07: Item 20: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAUDACITY.EXE , name=AUDACITY.EXE
20:22:07: Item 21: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_HTML_VC_CUSTOM.DLL , name=WXMSW28_HTML_VC_CUSTOM.DLL
20:22:07: Item 22: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_ADV_VC_CUSTOM.DLL , name=WXMSW28_ADV_VC_CUSTOM.DLL
20:22:07: Item 23: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_CORE_VC_CUSTOM.DLL , name=WXMSW28_CORE_VC_CUSTOM.DLL
20:22:07: Item 24: path=C:WINDOWSSYSTEMOLEACC.DLL , name=OLEACC.DLL
20:22:07: Item 25: path=C:WINDOWSSYSTEMOLEAUT32.DLL , name=OLEAUT32.DLL
20:22:07: Item 26: path=C:WINDOWSSYSTEMCOMDLG32.DLL , name=COMDLG32.DLL
20:22:07: Item 27: path=C:WINDOWSSYSTEMWINMM.DLL , name=WINMM.DLL
20:22:07: Item 28: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXBASE28_NET_VC_CUSTOM.DLL , name=WXBASE28_NET_VC_CUSTOM.DLL
20:22:07: Item 29: path=C:WINDOWSSYSTEMWSOCK32.DLL , name=WSOCK32.DLL
20:22:07: Item 30: path=C:WINDOWSSYSTEMMSWSOCK.DLL , name=MSWSOCK.DLL
20:22:07: Item 31: path=C:WINDOWSSYSTEMWS2_32.DLL , name=WS2_32.DLL
20:22:07: Item 32: path=C:WINDOWSSYSTEMRASAPI32.DLL , name=RASAPI32.DLL
20:22:07: Item 33: path=C:WINDOWSSYSTEMSECUR32.DLL , name=SECUR32.DLL
20:22:07: Item 34: path=C:WINDOWSSYSTEMSVRAPI.DLL , name=SVRAPI.DLL
20:22:07: Item 35: path=C:WINDOWSSYSTEMMSNET32.DLL , name=MSNET32.DLL
20:22:07: Item 36: path=C:WINDOWSSYSTEMMSPWL32.DLL , name=MSPWL32.DLL
20:22:07: Item 37: path=C:WINDOWSSYSTEMTAPI32.DLL , name=TAPI32.DLL
20:22:07: Item 38: path=C:WINDOWSSYSTEMRPCRT4.DLL , name=RPCRT4.DLL
20:22:07: Item 39: path=C:WINDOWSSYSTEMNETAPI32.DLL , name=NETAPI32.DLL
20:22:07: Item 40: path=C:WINDOWSSYSTEMNETBIOS.DLL , name=NETBIOS.DLL
20:22:07: Item 41: path=C:WINDOWSSYSTEMMPR.DLL , name=MPR.DLL
20:22:07: Item 42: path=C:WINDOWSSYSTEMWS2HELP.DLL , name=WS2HELP.DLL
20:22:07: Item 43: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXBASE28_VC_CUSTOM.DLL , name=WXBASE28_VC_CUSTOM.DLL
20:22:07: Item 44: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAMSVCP80.DLL , name=MSVCP80.DLL
20:22:07: Item 45: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAMSVCR80.DLL , name=MSVCR80.DLL
20:22:07: Item 46: path=C:WINDOWSSYSTEMOLE32.DLL , name=OLE32.DLL
20:22:07: Item 47: path=C:WINDOWSSYSTEMSHELL32.DLL , name=SHELL32.DLL
20:22:07: Item 48: path=C:WINDOWSSYSTEMCOMCTL32.DLL , name=COMCTL32.DLL
20:22:07: Item 49: path=C:WINDOWSSYSTEMSHLWAPI.DLL , name=SHLWAPI.DLL
20:22:07: Item 50: path=C:WINDOWSSYSTEMMSVCRT.DLL , name=MSVCRT.DLL
20:22:07: Item 51: path=C:WINDOWSSYSTEMUSER32.DLL , name=USER32.DLL
20:22:07: Item 52: path=C:WINDOWSSYSTEMGDI32.DLL , name=GDI32.DLL
20:22:07: Item 53: path=C:WINDOWSSYSTEMADVAPI32.DLL , name=ADVAPI32.DLL
20:22:07: Item 54: path=C:WINDOWSSYSTEMKERNEL32.DLL , name=KERNEL32.DLL
20:22:07: The avformat library happened to be statically linked
20:22:07: Returning PATH to normal...
20:22:07: Importing symbols...
20:22:07: Error: Couldn't find symbol 'avcodec_init' in a dynamic library (error 127: no se encontró el proceso especificado.)
20:22:07: Failed to load symbol avcodec_init
20:22:07: Trying to load from PATH. File name is avformat-52.dll
20:22:07: Looking up PATH...
20:22:07: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:22:07: Checking that is in PATH...
20:22:07: in PATH.
20:22:07: Loading avformat from avformat-52.dll
20:22:07: avformat loaded successfully. Acquiring the list of modules.
20:22:11: Looking for FFmpeg libraries...
20:22:11: mLibAVFormatPath is not empty, = avformat-52.dll
20:22:27: User-specified path = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:22:27: User-specified file exists. Success.
20:22:27: Trying to load FFmpeg libraries
20:22:27: mLibAVFormatPath is not empty, = C:Archivos de programaAudacity 1.3 Betaavformat-52.dll. Loading from it.
20:22:27: Looking up PATH...
20:22:27: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:22:27: Checking that C:Archivos de programaAudacity 1.3 Beta is in PATH...
20:22:27: not in PATH!
20:22:27: Appending ;C:Archivos de programaAudacity 1.3 Beta ...
20:22:27: Loading avformat from C:Archivos de programaAudacity 1.3 Betaavformat-52.dll
20:22:27: avformat loaded successfully. Acquiring the list of modules.
20:22:28: List acquired and consists of 57 modules
20:22:28: Item 0: path=C:WINDOWSSYSTEMSHDOCVW.DLL , name=SHDOCVW.DLL
20:22:28: Item 1: path=C:WINDOWSSYSTEMBROWSEUI.DLL , name=BROWSEUI.DLL
20:22:28: Item 2: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETADBGHELP.DLL , name=DBGHELP.DLL
20:22:28: Item 3: path=C:WINDOWSSYSTEMVERSION.DLL , name=VERSION.DLL
20:22:28: Item 4: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVFORMAT-52.DLL , name=AVFORMAT-52.DLL
20:22:28: Item 5: path=C:WINDOWSSYSTEMAVIFIL32.DLL , name=AVIFIL32.DLL
20:22:28: Item 6: path=C:WINDOWSSYSTEMMSVFW32.DLL , name=MSVFW32.DLL
20:22:28: Item 7: path=C:WINDOWSSYSTEMWOW32.DLL , name=WOW32.DLL
20:22:28: Item 8: path=C:WINDOWSSYSTEMDCIMAN32.DLL , name=DCIMAN32.DLL
20:22:28: Item 9: path=C:WINDOWSSYSTEMCRTDLL.DLL , name=CRTDLL.DLL
20:22:28: Item 10: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVCODEC-52.DLL , name=AVCODEC-52.DLL
20:22:28: Item 11: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPTHREADGC2.DLL , name=PTHREADGC2.DLL
20:22:28: Item 12: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETALIBMP3LAME-0.DLL , name=LIBMP3LAME-0.DLL
20:22:28: Item 13: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETALIBFAAC-0.DLL , name=LIBFAAC-0.DLL
20:22:28: Item 14: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVUTIL-49.DLL , name=AVUTIL-49.DLL
20:22:28: Item 15: path=C:WINDOWSSYSTEMMSIMG32.DLL , name=MSIMG32.DLL
20:22:28: Item 16: path=C:WINDOWSSYSTEMNTDLL.DLL , name=NTDLL.DLL
20:22:28: Item 17: path=C:WINDOWSSYSTEMRICHED32.DLL , name=RICHED32.DLL
20:22:28: Item 18: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSSC4_1882.DLL , name=SC4_1882.DLL
20:22:28: Item 19: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSHARD_LIMITER_1413.DLL , name=HARD_LIMITER_1413.DLL
20:22:28: Item 20: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSGVERB_1216.DLL , name=GVERB_1216.DLL
20:22:28: Item 21: path=C:WINDOWSSYSTEMMSACM32.DLL , name=MSACM32.DLL
20:22:28: Item 22: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAUDACITY.EXE , name=AUDACITY.EXE
20:22:28: Item 23: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_HTML_VC_CUSTOM.DLL , name=WXMSW28_HTML_VC_CUSTOM.DLL
20:22:28: Item 24: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_ADV_VC_CUSTOM.DLL , name=WXMSW28_ADV_VC_CUSTOM.DLL
20:22:28: Item 25: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_CORE_VC_CUSTOM.DLL , name=WXMSW28_CORE_VC_CUSTOM.DLL
20:22:28: Item 26: path=C:WINDOWSSYSTEMOLEACC.DLL , name=OLEACC.DLL
20:22:28: Item 27: path=C:WINDOWSSYSTEMOLEAUT32.DLL , name=OLEAUT32.DLL
20:22:28: Item 28: path=C:WINDOWSSYSTEMCOMDLG32.DLL , name=COMDLG32.DLL
20:22:28: Item 29: path=C:WINDOWSSYSTEMWINMM.DLL , name=WINMM.DLL
20:22:28: Item 30: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXBASE28_NET_VC_CUSTOM.DLL , name=WXBASE28_NET_VC_CUSTOM.DLL
20:22:28: Item 31: path=C:WINDOWSSYSTEMWSOCK32.DLL , name=WSOCK32.DLL
20:22:28: Item 32: path=C:WINDOWSSYSTEMMSWSOCK.DLL , name=MSWSOCK.DLL
20:22:28: Item 33: path=C:WINDOWSSYSTEMWS2_32.DLL , name=WS2_32.DLL
20:22:28: Item 34: path=C:WINDOWSSYSTEMRASAPI32.DLL , name=RASAPI32.DLL
20:22:28: Item 35: path=C:WINDOWSSYSTEMSECUR32.DLL , name=SECUR32.DLL
20:22:28: Item 36: path=C:WINDOWSSYSTEMSVRAPI.DLL , name=SVRAPI.DLL
20:22:28: Item 37: path=C:WINDOWSSYSTEMMSNET32.DLL , name=MSNET32.DLL
20:22:28: Item 38: path=C:WINDOWSSYSTEMMSPWL32.DLL , name=MSPWL32.DLL
20:22:28: Item 39: path=C:WINDOWSSYSTEMTAPI32.DLL , name=TAPI32.DLL
20:22:28: Item 40: path=C:WINDOWSSYSTEMRPCRT4.DLL , name=RPCRT4.DLL
20:22:28: Item 41: path=C:WINDOWSSYSTEMNETAPI32.DLL , name=NETAPI32.DLL
20:22:28: Item 42: path=C:WINDOWSSYSTEMNETBIOS.DLL , name=NETBIOS.DLL
20:22:28: Item 43: path=C:WINDOWSSYSTEMMPR.DLL , name=MPR.DLL
20:22:28: Item 44: path=C:WINDOWSSYSTEMWS2HELP.DLL , name=WS2HELP.DLL
20:22:28: Item 45: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXBASE28_VC_CUSTOM.DLL , name=WXBASE28_VC_CUSTOM.DLL
20:22:28: Item 46: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAMSVCP80.DLL , name=MSVCP80.DLL
20:22:28: Item 47: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAMSVCR80.DLL , name=MSVCR80.DLL
20:22:28: Item 48: path=C:WINDOWSSYSTEMOLE32.DLL , name=OLE32.DLL
20:22:28: Item 49: path=C:WINDOWSSYSTEMSHELL32.DLL , name=SHELL32.DLL
20:22:28: Item 50: path=C:WINDOWSSYSTEMCOMCTL32.DLL , name=COMCTL32.DLL
20:22:28: Item 51: path=C:WINDOWSSYSTEMSHLWAPI.DLL , name=SHLWAPI.DLL
20:22:28: Item 52: path=C:WINDOWSSYSTEMMSVCRT.DLL , name=MSVCRT.DLL
20:22:28: Item 53: path=C:WINDOWSSYSTEMUSER32.DLL , name=USER32.DLL
20:22:28: Item 54: path=C:WINDOWSSYSTEMGDI32.DLL , name=GDI32.DLL
20:22:28: Item 55: path=C:WINDOWSSYSTEMADVAPI32.DLL , name=ADVAPI32.DLL
20:22:28: Item 56: path=C:WINDOWSSYSTEMKERNEL32.DLL , name=KERNEL32.DLL
20:22:28: The avformat library happened to be statically linked
20:22:28: Returning PATH to normal...
20:22:28: Importing symbols...
20:22:28: Error: Couldn't find symbol 'avcodec_init' in a dynamic library (error 127: no se encontró el proceso especificado.)
20:22:28: Failed to load symbol avcodec_init
20:22:28: Trying to load from PATH. File name is avformat-52.dll
20:22:28: Looking up PATH...
20:22:28: PATH = C:WINDOWS;C:WINDOWSCOMMAND
20:22:28: Checking that is in PATH...
20:22:28: in PATH.
20:22:28: Loading avformat from avformat-52.dll
20:22:28: avformat loaded successfully. Acquiring the list of modules.
20:22:29: List acquired and consists of 57 modules
20:22:29: Item 0: path=C:WINDOWSSYSTEMSHDOCVW.DLL , name=SHDOCVW.DLL
20:22:29: Item 1: path=C:WINDOWSSYSTEMBROWSEUI.DLL , name=BROWSEUI.DLL
20:22:29: Item 2: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETADBGHELP.DLL , name=DBGHELP.DLL
20:22:29: Item 3: path=C:WINDOWSSYSTEMVERSION.DLL , name=VERSION.DLL
20:22:29: Item 4: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVFORMAT-52.DLL , name=AVFORMAT-52.DLL
20:22:29: Item 5: path=C:WINDOWSSYSTEMAVIFIL32.DLL , name=AVIFIL32.DLL
20:22:29: Item 6: path=C:WINDOWSSYSTEMMSVFW32.DLL , name=MSVFW32.DLL
20:22:29: Item 7: path=C:WINDOWSSYSTEMWOW32.DLL , name=WOW32.DLL
20:22:29: Item 8: path=C:WINDOWSSYSTEMDCIMAN32.DLL , name=DCIMAN32.DLL
20:22:29: Item 9: path=C:WINDOWSSYSTEMCRTDLL.DLL , name=CRTDLL.DLL
20:22:29: Item 10: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVCODEC-52.DLL , name=AVCODEC-52.DLL
20:22:29: Item 11: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPTHREADGC2.DLL , name=PTHREADGC2.DLL
20:22:29: Item 12: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETALIBMP3LAME-0.DLL , name=LIBMP3LAME-0.DLL
20:22:29: Item 13: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETALIBFAAC-0.DLL , name=LIBFAAC-0.DLL
20:22:29: Item 14: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAVUTIL-49.DLL , name=AVUTIL-49.DLL
20:22:29: Item 15: path=C:WINDOWSSYSTEMMSIMG32.DLL , name=MSIMG32.DLL
20:22:29: Item 16: path=C:WINDOWSSYSTEMNTDLL.DLL , name=NTDLL.DLL
20:22:29: Item 17: path=C:WINDOWSSYSTEMRICHED32.DLL , name=RICHED32.DLL
20:22:29: Item 18: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSSC4_1882.DLL , name=SC4_1882.DLL
20:22:29: Item 19: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSHARD_LIMITER_1413.DLL , name=HARD_LIMITER_1413.DLL
20:22:29: Item 20: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAPLUG-INSGVERB_1216.DLL , name=GVERB_1216.DLL
20:22:29: Item 21: path=C:WINDOWSSYSTEMMSACM32.DLL , name=MSACM32.DLL
20:22:29: Item 22: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAAUDACITY.EXE , name=AUDACITY.EXE
20:22:29: Item 23: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_HTML_VC_CUSTOM.DLL , name=WXMSW28_HTML_VC_CUSTOM.DLL
20:22:29: Item 24: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_ADV_VC_CUSTOM.DLL , name=WXMSW28_ADV_VC_CUSTOM.DLL
20:22:29: Item 25: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXMSW28_CORE_VC_CUSTOM.DLL , name=WXMSW28_CORE_VC_CUSTOM.DLL
20:22:29: Item 26: path=C:WINDOWSSYSTEMOLEACC.DLL , name=OLEACC.DLL
20:22:29: Item 27: path=C:WINDOWSSYSTEMOLEAUT32.DLL , name=OLEAUT32.DLL
20:22:29: Item 28: path=C:WINDOWSSYSTEMCOMDLG32.DLL , name=COMDLG32.DLL
20:22:29: Item 29: path=C:WINDOWSSYSTEMWINMM.DLL , name=WINMM.DLL
20:22:29: Item 30: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXBASE28_NET_VC_CUSTOM.DLL , name=WXBASE28_NET_VC_CUSTOM.DLL
20:22:29: Item 31: path=C:WINDOWSSYSTEMWSOCK32.DLL , name=WSOCK32.DLL
20:22:29: Item 32: path=C:WINDOWSSYSTEMMSWSOCK.DLL , name=MSWSOCK.DLL
20:22:29: Item 33: path=C:WINDOWSSYSTEMWS2_32.DLL , name=WS2_32.DLL
20:22:29: Item 34: path=C:WINDOWSSYSTEMRASAPI32.DLL , name=RASAPI32.DLL
20:22:29: Item 35: path=C:WINDOWSSYSTEMSECUR32.DLL , name=SECUR32.DLL
20:22:29: Item 36: path=C:WINDOWSSYSTEMSVRAPI.DLL , name=SVRAPI.DLL
20:22:29: Item 37: path=C:WINDOWSSYSTEMMSNET32.DLL , name=MSNET32.DLL
20:22:29: Item 38: path=C:WINDOWSSYSTEMMSPWL32.DLL , name=MSPWL32.DLL
20:22:29: Item 39: path=C:WINDOWSSYSTEMTAPI32.DLL , name=TAPI32.DLL
20:22:29: Item 40: path=C:WINDOWSSYSTEMRPCRT4.DLL , name=RPCRT4.DLL
20:22:29: Item 41: path=C:WINDOWSSYSTEMNETAPI32.DLL , name=NETAPI32.DLL
20:22:29: Item 42: path=C:WINDOWSSYSTEMNETBIOS.DLL , name=NETBIOS.DLL
20:22:29: Item 43: path=C:WINDOWSSYSTEMMPR.DLL , name=MPR.DLL
20:22:29: Item 44: path=C:WINDOWSSYSTEMWS2HELP.DLL , name=WS2HELP.DLL
20:22:29: Item 45: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAWXBASE28_VC_CUSTOM.DLL , name=WXBASE28_VC_CUSTOM.DLL
20:22:29: Item 46: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAMSVCP80.DLL , name=MSVCP80.DLL
20:22:29: Item 47: path=C:ARCHIVOS DE PROGRAMAAUDACITY 1.3 BETAMSVCR80.DLL , name=MSVCR80.DLL
20:22:29: Item 48: path=C:WINDOWSSYSTEMOLE32.DLL , name=OLE32.DLL
20:22:29: Item 49: path=C:WINDOWSSYSTEMSHELL32.DLL , name=SHELL32.DLL
20:22:29: Item 50: path=C:WINDOWSSYSTEMCOMCTL32.DLL , name=COMCTL32.DLL
20:22:29: Item 51: path=C:WINDOWSSYSTEMSHLWAPI.DLL , name=SHLWAPI.DLL
20:22:29: Item 52: path=C:WINDOWSSYSTEMMSVCRT.DLL , name=MSVCRT.DLL
20:22:29: Item 53: path=C:WINDOWSSYSTEMUSER32.DLL , name=USER32.DLL
20:22:29: Item 54: path=C:WINDOWSSYSTEMGDI32.DLL , name=GDI32.DLL
20:22:29: Item 55: path=C:WINDOWSSYSTEMADVAPI32.DLL , name=ADVAPI32.DLL
20:22:29: Item 56: path=C:WINDOWSSYSTEMKERNEL32.DLL , name=KERNEL32.DLL
20:22:29: The avformat library happened to be statically linked
20:22:29: Importing symbols...
20:22:29: Error: Couldn't find symbol 'avcodec_init' in a dynamic library (error 127: no se encontró el proceso especificado.)
20:22:29: Failed to load symbol avcodec_init[Edit] I put your file inside a [code] tag to make it easier to read and copy - stf
- Quality Assurance
Thanks for that, meantime could you delete the dbghelp.dll you downloaded before, and try putting this older version in the Audacity installation folder instead? Just double-click the .exe. That will extract the contents to wherever you want, then take the dbghelp.dll from the "x86" folder. The dll is supposed to be for Windows 95, 98 and NT, but I think it has more chance of working on ME than the other one.
If FFmpeg is still incompatible, can you post the Debug output again?
Thanks
Thanks
