I'm used to selecting a portion of audio, hitting "delete" and that portion vanishes.
Lately, however - and I've tested this on both 1.3 and 1.6 - when I have *nothing* selected, and I hit "delete" (accidentally), *everything* vanishes. Every single channel goes blank.
Any idea why this is happening, and how I can stop it from happening? Any suggestions would be appreciated.
Thanks much.
delete - when nothing is selected
sagetyrtle
waxcylinder
Re: delete - when nothing is selected
I suspect that you have the ticbox set for "Select all adudio in project, if none selected" - accessed via Edit > Preferences > Interface
If so then uncheck this selection.
sagetyrtle
Aha! Right you are. I can see how that's a really useful ticbox for using Export - I wonder if, in a future release, there could be some exception to the Delete key?
In any case, thanks much for your help. That was driving me insane.
<<<I wonder if, in a future release, there could be some exception to the Delete key?>>>
We've been fighting forever to get that feature. In the old versions of Audacity, if you didn't select anything, all the effects keys would drop dead. The forum is littered with: "Why are all the effects grayed out?" The answer is you didn't select any audio. Most people naturally assume that if you do select a tool, that it affects the whole show--but you can turn that off.
In any event, UNDO brought it all back, right?
