I export the entire track. I select the track by clicking on the track control box (like I have always done). Export Selected. With 1.3.6 I use Other Uncompressed Files with the option for a 32 bit WAV with the default encoding.stevethefiddle wrote:How are you "Exporting"?
I presume that you are using "Export Selected" from the File menu?
If so, how do you ensure that you have selected from precisely 0.000 seconds?
If you want I'll zip up the sine wav test project along with my WAV files and make it available for download off of my website. It won't be too large of a file
Tony
