I just want to inform you that the current release 1.3.6-Beta does no longer run under Windows 98!
And before someone asks: of course I´ve downloaded the correct (i.e. non-unicode) version ...
I can´t say anything about the installation/setup-file, because I prefer ZIP-packages whenever available.stevethefiddle wrote: I've not had chance to look at this yet, but when you say that it does not run, could you give a bit more information - do you mean it won't install, or it will install but won't launch, or it installs and launches but then crashes.....
thanks - I´ve tried this one, but it has exactly the same problem.Gale Andrews wrote:fhub, (or anyone else on Windows 98), would you be able to try this build
http://www.gaclrecords.org.uk/audacity- ... s-ansi.zip
and see if you have the same problem trying to launch it? I'm not sure it will help, but it may give us some more clues.
Well, a simple explanation might be that certainly VERY few people would join this forum just because the new beta doesn´t run anymore under Win98 - most people would simply ignore this new beta and stay with the last working version.What I don't understand is that there have only been two reports of this problem despite some 13000 downloads to date of the ANSI build of 1.3.6 advertised as for Windows 98 and ME.
Yes, now it´s working again, many thanks!Gale Andrews wrote: ...
which should make it compatible with Windows 98. Can you try it again please ?
We are still compiling with Visual Studio 2005 as before. The included wxWidgets dlls are there because Audacity 1.3.6 and future versions are now built modularly against wxWidgets, rather than being statically linked to it. Widgets builds against the Microsoft dll's too, so those dll's are also included. At the moment I'm still hoping to see a non-Unicode 1.3.7 and then 1.4.0 stable for Windows 98/ME. But that will be the end, and Beta 1.5.x will only support Windows 2000 and later.fhub wrote:But from the included DLLs msvc?80.dll I see that you´ve switched to a new compiler version starting with the new beta 1.3.6, and so I´m quite sure that similar problems with Win98-incompatible API functions will reappear again very soon in your further development. So it may be a good idea to keep this beta above as "probably the last Audacity working in Win98" ...
