Can't import flac
Re: Can't import flac
Post by Gale Andrews » Sat May 23, 2009 7:34 am
Mike Hunt wrote:This one better work. http://drop.io/mikehunt
Thanks. The file imports fine in 1.3.8 Alpha (Unicode), either via FFmpeg or the inbuilt FLAC importer. This might possibly be due to some improvements we have made in metadata tag handling since 1.3.7. If you want to try it, download this:
http://www.gaclrecords.org.uk/audacity- ... -alpha.zip
You can either run it as a standalone, or extract the files into the 1.3.7 directory and accept the prompt to overwrite the existing files.
Mike Hunt
Post by Mike Hunt » Sat May 23, 2009 2:39 pm
Great, it works in 1.3.8. But every time I start it up, it says "Couldn't find symbol "main" in a dynamic library (eppror 127: the specified procedure could not be found.)".
But since it seems to work ok, I guess it doesn't matter.
Thanks for helping me
Post by Gale Andrews » Thu May 28, 2009 5:28 am
Mike Hunt wrote: every time I start it up, it says "Couldn't find symbol "main" in a dynamic library (eppror 127: the specified procedure could not be found.)"
What version of Windows, and are you just double-clicking the executable? Have you got all the files in the zip and are you running them from their own folder?
