Oninat
Post
by Oninat » Mon Mar 19, 2012 12:00 pm
Greetings all.Can any one assist me with my query.My Beta version of the Audacity
Software is version 1.3.11 operating on Windows 7.The Dynaudio Acoustics set speakers are connected to
the M-Audio Pro.How does one have the audio box recognize the speakers all the sound at the moment is coming out of the
Computer speakersMy acoustic guitar with Highlander pick-up is connected to the Pro.Its recording fine and the sound is heard only thru the computer speakers.Any suggestions on how to activate the speakers connected to the M-Audio.Pls assist.My attempt in preferences to have the Pro recognize the speakers fails every time .What can I do to make the workstation function and playback the recordings thru the speakers.Thank you for any help.
Tani down under perplexed.
http://www.youtube.com/folk806
Enjoy!
- Site Admin
Post
by steve » Mon Mar 19, 2012 4:00 pm
Audacity 2.0 is now available and replaces all previous versions of Audacity. It includes several bug fixes so it is a recommended upgrade:
To tell Audacity to play back via the M-Audio Pro you will need to set the Placyback Output in the Device Toolbar to the M-Audio option (it may just be listed as a "USB" option). For help with the Device Toolbar:
http://manual.audacityteam.org/man/Device_Toolbar
Oninat
Post
by Oninat » Mon Mar 19, 2012 7:06 pm
Steve thank you for your assistance.Considering the upgrade to version 2 are the drivers included in this version and what procedure to you recommend for removing 1.3 .11and installing version 2.Or do you simply install version 2without removal of 1.3 .Let me know.thank you again.Tani.
- Site Admin
Post
by steve » Mon Mar 19, 2012 9:44 pm
Audacity does not include any device drivers - it uses the standard computer sound system. If your sound card is correctly installed and working then that's all that Audacity needs.
Yes I'd recommend uninstalling Audacity 1.3.11 first. If you have a standard installation of 1.3.11 you should be able to do that through the Windows Control Panel (Add/Remove Software, or whatever they call it these days).
Your Preference settings should still remain after uninstalling 1.3.11 so that they are picked up by Audacity 2.0.
You can download Audacity 2.0 from here:
