Side by Side configuration
kewlrane
Post by kewlrane » Fri Feb 24, 2012 5:36 pm
I installed on my vista laptop and when I try to launch audacity I get an create error 14001
side by side configuration is incorrect. how can I fix this?
Re: Side by Side configuration
Post by steve » Fri Feb 24, 2012 7:38 pm
If you have the 32 bit version of Vista, download Microsoft Visual C++ 2008 SP1 Redistributable Package (x86). Double-click on the downloaded "C:vcredist_x86.exe" file to run it and follow the instructions. If you are asked whether you want to uninstall or repair, choose "Repair".
If you are running a 64-bit version of Vista, download Microsoft Visual C++ 2008 SP1 Redistributable Package (x64) then double-click on the downloaded "C:vcredist_x64.exe" file and follow the instructions. If you are asked whether you want to uninstall or repair, choose "Repair".
Post by Gale Andrews » Sun Feb 26, 2012 6:52 pm
Thanks, Steve. To save all the typing when this problem happens, you can now link to this FAQ:
http://manual.audacityteam.org/man/FAQ: ... -Ins#probs
