DD 5.1 cutting
Re: DD 5.1 cutting
Could you try and make your images a bit smaller - it's difficult to view this topic with such big images in it.
Try playing one track at a time (use the "Solo" button) so that you can hear what is in each track.
Re: DD 5.1 cutting
ok, this image is scaled 75%.
hmmm see please here at the end...perhaps some track are corrupted? the end point is different, this will cause the async...
track 1 , 2 end after the remainings tracrks...
- Attachments
- look at the end.
- untitled2.jpg (478.94 KiB) Viewed 1105 times
Re: DD 5.1 cutting
The picture is much more clear thank you
When you view the forum page, if you click on an image that has scroll bars, the image will expand vertically to reveal the full image height.
Where did these tracks come from? Have you edited them? I don't understand what you are trying to say.
I can see that track 1 and 2 are longer than the other tracks. Is that the problem?anuswara wrote:hmmm see please here at the end...perhaps some track are corrupted? the end point is different, this will cause the async...
Re: DD 5.1 cutting
thank you for your reply.
process 1) yesterday:
file ac3 > I did extract 3 songs. ok. all went fine.
process 2) today. the same process but with larger (and very important) file.
file ac3 > I would like to do the same process as yesterday, but today it is was wrong. I am unable .
all my ac3 file come from the same recording (the recording playback fine!).
1) file TS
2) demux it with tsmuxergui
3) I become H264 (I delete this file) + AC3 dd 5.1
no editing process.
the SAME record as yesterday.
the SAME demuxing process, but today 2 tracks seems to be longer... (?!?) longer after demuxing doing the same process with tsmuxergui. these 2 longer tracks cause the audio's overlapping, I guess.
very odd:
the same TS file. the same process with demuxer. but different results.
1) file TS
no editing process.
very odd:
Re: DD 5.1 cutting
I think the problem has more to do with the format conversions than it has to do with Audacity. These people will probably be able to help you better:
http://www.doom9.net/
On that page, click on "Quick Links" and select "More".
Also check out their forum.
Re: DD 5.1 cutting
thank you. I appreciate your help.
I will try doom9.
I will try doom9.
Re: DD 5.1 cutting
here the issue.
channel l,r are longer than other channels.
commercials has been broadcasted dolby 2.0
and the music in dd 5.1
the original file playbacks fine.
I guess that Audacity is considering the whole file ac3 6 channels instaed of 6 channels but 2 channels during the commercials.
Re: DD 5.1 cutting
That sounds right.
I don't think that Audacity has any way of knowing which parts should be 2 channel - Audacity will just see 6 audio streams.
Re: DD 5.1 cutting
steve wrote:I think the problem has more to do with the format conversions than it has to do with Audacity. These people will probably be able to help you better:
thank you for your suggestion.
I resolved my problems with delaycut from doom9, it seems that the changes dd5.1/2.0 do not generate issues
