Many problems 1 No option for mp3
helpmeplease111
Hi I not a big computer user but have sucessfully loaded this program before but for me it the most fustrating program yet the best one if I can get it to work. I have windows7 32 bit. I have downloaded audacity http://audacity.googlecode.com/files/au ... 1.3.14.exe but it wont let me load it in program file it loads it somewhere else does this matter. Also load lame http://lame1.buanzo.com.ar/Lame_v3.99.3_for_Windows.exe again it wont let me load it in programe files administrator wont let me so i load it in the same place as the other. I set it up and all but carnt find it open anywhere the lame_enc.dll anywhere. When useing adacity when I record and then try to export there is no option for mp3 it opens to the adacity file where it give me help,languages, modules,nyquist,plugins. I just want to use it for recording my old cassettes onto the computer.
Re: Many problems 1 No option for mp3
Do you have Administrative rights on the computer? (Do you know the Administrator password?)
If you do, then all you (should) need to do is to run the .exe (installation) files and follow the on-screen instructions and entering the Administrator password when prompted.
As with most programs on Windows 7, to install the program correctly you will need Administrative access, however if you don't it is still possible to use Audacity, though it requires a different procedure to set it up.
helpmeplease111
No I dont know the password I should it my computer and have never had a problem it bugs me this has this option. How do I get the password is it as easy as that? Thx steve for trying to help i must warn you I dont know much. Differnet procedure scares me. lol.steve wrote:Do you have Administrative rights on the computer? (Do you know the Administrator password?)
OK, I'll try to be gentle
Do you know what a "ZIP" file is and how to "extract" a ZIP file?
helpmeplease111
I know you are not going to like this but I will answer it like this I dont know much but will try anything that seen logical with out getting me into too much trouble. I loaded winzip yesterday, hearing some people need to unzip things so I loaded the zip form of lame but when go find the file I not sure I am doing it right when i go the extract it it dont appear to be extracted if that make sence my opperating system is diffenent to others who are tried so i dont know If I am got the right steps but will try anying. Cheers. Stevesteve wrote:OK, I'll try to be gentle
- Quality Assurance
Can you right-click over this link:
http://lame1.buanzo.com.ar/lame_enc.dll
then choose "Save Target as" or "Save link as". A window opens. Can you find your way from there using the buttons or links on the left to open the folder you have Audacity installed in - the one with the "help" and "modules" folders and audacity.exe. Save lame_enc.dll in that folder Audacity is installed in. Audacity should then recognise the lame file.
helpmeplease111
AHHHHHHHHHHHHHHHHH No matter where i save it when I try to do what you are saying it comes up with I dont have administrator acesss do want to save it in susans sermon I click yes for once then when I want to get lame it finds s sermons but the A file is not their though if I go through and open it to get other file theres lots in their.Gale Andrews wrote:Can you right-click over this link:
helpmeplease111
i have done all that Gale its does work that way either.Surly there is an easyer way? I hate windows7.
This may take some time, but if we go through a step at a time we have a good chance of success.
So what is the current situation with Audacity?
You said that you had trouble installing it (to be expected if you don't have Admin rights).
Are you able to run Audacity?
- Quality Assurance
Did you install Windows 7 on the computer? Whoever did that has an administrator account and knows the password.
