Recording of Skype Call - caller only
owengreaves
Post by owengreaves » Fri Jan 13, 2012 10:20 pm
Hi There,
I'm sure this has been covered at some point but I'm a newbie : )
I recorded a Skype call, which went well from an audio level point of view. The problem was, it recorded the caller or the person I called well, but my mic was not picked up at all, so you only hear the caller, and gaps when I was speaking.
What did I miss here, I've done calls before and they worked but I just upgraded to 1.3.14, so I'm not sure if I missed something.
Any ideas or tips for me please?
Thanks,
Owen
Re: Recording of Skype Call - caller only
Post by kozikowski » Fri Jan 13, 2012 10:27 pm
Win7 Laptop?
owengreaves
Post by owengreaves » Fri Jan 13, 2012 10:27 pm
Ya, Win 7 Laptop.
Post by kozikowski » Fri Jan 13, 2012 10:32 pm
Good Ol' Win7.
Since it partially works now, I'd probably start by turning off Windows Conferencing.
http://manual.audacityteam.org/man/FAQ: ... hancements
owengreaves
Post by owengreaves » Fri Jan 13, 2012 10:45 pm
That did not solve anything, but thanks. It's like it only recorded the caller and not me...not sure why, I used the Stereo Mix in Audacity, he was able to hear me when I talked, it just didn't record it, as if the device (my mic) didn't exist.
Owen
Post by kozikowski » Sat Jan 14, 2012 12:23 am
That's not what you said the first time. You said you recorded very badly.
What you have now is perfectly normal. Skype takes over the sound channels and will not let you record both sides no matter which sound device or adjustment you make. One of our posters went for days under the assumption that there must be a way.
There wasn't. If you do dig in the internals of your computer enough, you can force it to work, but then Skype works badly.
We recommend Total Recorder, one of the four Pamela versions and I think there's a software package called Skype Recorder.
http://www.pamela.biz/en/
http://www.highcriteria.com/
As I recall, what they do is "make" a second sound device in memory and use that instead of the computer's own sound card.
owengreaves
Post by owengreaves » Mon Jan 16, 2012 12:28 pm
Sorry if I wasn't clear enough, thanks for the links, I'll check them out.
