Recording Problem
Recording Problem
From time to time, I have run into this problem, but I can not remember how to respong. When I try to record, I get this message, : "Error while opening sound decice. Please check the input device settings and the project sample rate." Well, the unput device is working. Any suggestions?
Re: Recording Problem
What is the input device? USB microphone?
Sometimes you can force it to work by changing Audacity Preferences to 44100, 16-bit (not 32), Stereo. OK and restart Audacity. See if that helps. If you have a USB microphone, you might need to select Mono instead of Stereo.
Make sure Audacity Preferences or the input drop-down menu has the thing selected that you want.
1/13/12
Thank you Koz! Your suggestions worked.
Tony
Tony
