How do I record from Yamaha PSR E413 Keyboard
Tony Fendall
Post by Tony Fendall » Wed Jan 11, 2012 1:45 pm
My keyboard is connected to my PC and I can run Audacity, but I can only record through my mic.
I can't see my keyboard in the input device drop down.
What do I do to record direct from the invisible keyboard?
Any help much appreciated.
Regards
Tony
bgravato
Re: How do I record from Yamaha PSR E413 Keyboard
Post by bgravato » Wed Jan 11, 2012 5:47 pm
How are you connecting the keyboard to the computer?
Audacity does not support recording from MIDI devices.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Tony Fendall
Post by Tony Fendall » Thu Jan 12, 2012 10:19 am
bgravato wrote:How are you connecting the keyboard to the computer?
I discovered that a USB connection does not work, so went out and bought a cable for the 'phones' socket and plugged into the sound card.
Everything works well now.
Thanks for your input.
Regards
Tony :)
