Help!
I am very new at this Audacity audio editing program. I have a three-section taped interview loaded on my computer. I used Audacity successfully to edit one section today. But when I tried to export the edited material, Audacity would not allow me to do so. I had to download a program called "Lame" to be able to export it to a folder on my desktop.
OK--but now I want to insert the edited sound file into an existing power point slide program. I am unable to do so.
Does anyone know how I can convert (or re-name or whatever) my "Audacity Project File" into some format which can be added to a power point slide show?
Thank you for any help you can give me.
Julie
Inserting edited audio into power point program
Re: Inserting edited audio into power point program
According to this...
http://office.microsoft.com/en-us/power ... px#BMsound
... you can use any WAV sound file which means you didn't need the MP3 software. Audacity exports WAV from your open Project naturally.
File > Export > WAV (Microsoft) 16-bit PCM
