dynamic use of spitfish vst
mark2atsafe
Post by mark2atsafe » Thu Jan 05, 2012 12:01 am
Hi folks,
New user here. First off, this is great software. Impressed with both it and the user community.
Anyway, I'm trying to remove sibilance from a recording. I've installed the Spitfish vst and all appears well.
However, I'm not sure quite how to use it. The Spitfish manual states:
Every fish fillet is a dynamics tool, so it makes no sense to pass only a portion of the signal to it. Dynamic
effects devices like this are made to process the entire signal to be as effective as possible.
But when I'm using it in Audacity it doesn't seem dynamic at all. I can fiddle with the settings, and apply it to the file, and it does appear to help. But I'm thinking that it should be able to "listen" to the recording while it is being played, so that I can adjust the sensitivity to the optimum level before I apply it.
Is this possible with Audacity? Effects are greyed out while playing the recording, so that doesn't work.
Or would it only work for live input from a microphone (I can see how that might be the case).
Thanks for any suggestions. I hope I've explained the scenario properly.
Re: dynamic use of spitfish vst
Post by kozikowski » Thu Jan 05, 2012 2:16 am
Audacity doesn't do anything in real time, so post processing is the rule.
Audacity doesn't support every possible plugin. If the tool needs custom control panels and fancy graphics, then it's may not work right in Audacity. You may get the "default" settings and no way to change them.
mark2atsafe
Post by mark2atsafe » Thu Jan 05, 2012 3:36 am
OK. That's good to know. Thanks for the response.
