Soundwave Form Changed - Put It Back?
TommyMacLuckie
Post by TommyMacLuckie » Tue Jan 03, 2012 4:59 pm
It went from looking like (not exactly this one)
to having it all start at the bottom and go to the top and resemble really whacky UPCs. Makes zero sense.
Did I press something? I can not figure it out at all, what to look for to make it go back. It resembles nothing that can work. Using it for editing songs and now it's just a mess.
Re: Soundwave Form Changed - Put It Back?
Post by kozikowski » Tue Jan 03, 2012 5:42 pm
You can get that if you accidentally magnify the waveform. Cursor over to the vertical stripe to the left of the waves so the cursor turns into a [+] sign. Press and hold the shift key while you click. It may need multiple clicks to bring you back to normal, +1 to -1.
TommyMacLuckie
Post by TommyMacLuckie » Tue Jan 03, 2012 5:46 pm
Thanks!
I saw another post and something about the amplitude so I started messing with it - wow. You'd need a really big widescreen to see some of the way it gets magnified. But I got it to get back to normal.
IORRian?
