I-Tunes will not open
DrAndy
Post by DrAndy » Mon Jan 02, 2012 10:53 pm
I-tunes will not open after I use Audacity. Have to reboot or redownload I-tunes software.
Re: I-Tunes will not open
Post by Gale Andrews » Tue Jan 03, 2012 12:44 am
If rebooting makes a difference thus suggests you may be below the Audacity system requirements:
http://audacityteam.org/download/beta_windows#sysreq
Make sure you are launching iTunes with its installed executable, not by double-clicking files that may have been associated previously with iTunes.
