Hi,
I am trying to export audacity file using lame enc dll but the program says can't open the library. But the same dll and version 1.3 works on my 64-bit vista. Is there some setting that I need to do for using on 32-bit vista. Any help in this regard is very much appreciated.
kurudi
LAME on 32 bit Vista (SOLVED)
- Quality Assurance
Re: audacity on 32 bit Vista
Sometimes one build will work on one machine but not others.
Please try one of these:
* Lame 3.99.3 from http://www.gaclrecords.org.uk/lame_v3.9 ... indows.exe
* Lame 3.98.4 from http://forum.audacityteam.org/download/file.php?id=2998 .
By the way you posted in the 1.2 Windows board. Please use Audacity 1.3.14 Beta on Vista or 7:
http://audacity.googlecode.com/files/au ... 1.3.14.exe
Gale,
Thanks and 99.3 version worked. Have a wonderful new year.
kurudi
kurudi
Re: LAME on 32 bit Vista (SOLVED)
Topic moved to Audacity 1.3.x forum and marked as solved.
