saving to WAV file
Re: saving to WAV file
Post by Gale Andrews » Sun Jan 01, 2012 2:36 am
web wrote:
Gale Andrews wrote: Are you up for trimming one of your mixes to a few seconds, saving as an Audacity project (.aup file and _data folder, making sure any files are copied in at File > Check Dependencies) then export a WAV for comparison? Here are some places you could upload to (zip the WAV and project into one folder):
http://www.yousendit.com
http://www.megaupload.com
http://www.sendspace.com
I think you lost me. When I'm done mixing, I hit save project. Then i reopen it and save it as a mix, which I then render all the tracks down to one, or two stereo. then I hit export and save it as a WAV file. Is there more i should be doing?
The idea of the above was so we could compare the audio quality stored in the project with that in an exported WAV file (if you still have this problem). It might give us some clues as to the issue you are encountering.
If you still have this issue I also suggest you download 1.3.14 from this link:
http://audacity.googlecode.com/files/au ... 1.3.14.exe
and install it over your current "1.3 Beta (Unicode) (.inc)". That way, we know which version of Audacity you have and where you got it from.
Also please tell us if you are choosing "WAV (Microsoft) signed 16-bit PCM" for exports.
Also please tell us if you are using 44100 Hz or higher project rate (look bottom left of the Audacity window).
If you are not doing both those things it probably explains your problem.
Edgar
Forum Crew
Post by Edgar » Sun Jan 01, 2012 8:02 pm
web wrote:I think you lost me.
[edit] Gale replied while I was composing my reply so attend to what he said first!
Sometimes we elves over-estimate the abilities or understanding of the user to which we are replying; sometimes our replies are a bit over-detailed and boring; it is hard to strike a good balance; my apologies in advance for the excruciating details which follow!
First, it looks like you may be running an old (and maybe even non-authentic) Audacity. Unless you are running Windows98, ME or 2000 you should go here:
http://audacityteam.org/download/beta_windows
and get the current 1.3.14 beta Windows 2000/XP/Vista/7 installer. If you are running Win2000 you should try that version also but make sure Win2k is completely updated to the most current service patch first.
If this update does not resolve your issue look here:
http://manual.audacityteam.org/man/Pref ... references
for details on how to reset your configuration file. Do NOT delete your old config file--rename it; this will allow you to restore it after testing!
If these do not resolve your issue we will need to have a sample of what you are trying to export so we may test and recreate your issue. To do this we will need an Audacity Project (which is both an AUP file and a data folder containing the actual audio) and a bad WAV file created from the Project.
Before doing anything else, make sure all files are copied in by choosing menu item File > Check Dependencies; if you have questions on this let us know before proceeding!
If your "bad" WAV is longer than 4 minutes (or you have limited network access):
Try to create the smallest Project which displays the problem--start with a "bad" Project and shorten each Track by 50% (assuming all tracks are the same length, the idea is to shorten the WAV by 50% but keep the first half audibly intact), Save As with a new name so the original is kept intact, export and test a WAV...
1) If the problem is still there close the 50% Project, reopen the original and shorten all tracks by 75%, Save As with a new name, export & test--continue shortening the original and testing until you get as small a practical (when your % difference gets down to under a minute that is plenty good enough).
2) If the problem is gone close the 50% Project, reopen the original and shorten all tracks by 25%, Save As with a new name, export & test--continue this process until you get as small a Project as practical (if 25% reduction yields a good WAV jump immediately to 5% reduction of the original).
When you have reduced your example (if needed) you will need to post it some where for us to download. It will need to be zipped up (7Zip is fine as is standard Zip); you will need to zip up the AUP, its data folder and the WAV. If you have a Project called badWave there will be a file called:
badWave.aup
and a folder called:
badWave_data
both will be in the same folder in which you saved the Project.
Zip both of them along with the WAV file which exhibits the problem and post them to one of the locations Gale suggested:
After you do so let us know the URL (the upload service will supply this when you do the upload--copy & paste that info into your reply to this).
-Edgar
running Audacity personally customized 2.0.6 daily in a professional audio studio
occasionally using current Audacity alpha for testing and support situations
64-bit Windows Pro 10
