copy using selection toolbar (SOLVED)
perturbation
Post by perturbation » Mon Dec 26, 2011 10:20 pm
I simply want to copy out a section of an mp3 and save it as a separate mp3. I have defined the selection using the selection toolbar by entering the time of the selection start and end, but copy is not available as an option. How can I use the selection toolbar to define the selection I want to copy , and then copy it? I've been trying this in different ways for 20 minutes - I suspect I am missing something simple.
Thanks in advance!
billw58
Re: copy using selection toolbar
Post by billw58 » Mon Dec 26, 2011 11:16 pm
Make sure you are in Stop mode, not Pause mode.
-- Bill
perturbation
Re: copy using selection toolbar (SOLVED)
Post by perturbation » Tue Dec 27, 2011 2:05 am
Thanks very much for your quick and helpful response -
Have a good new year!
